Heaviest Cut Compound?
I feel like the Autopia comparison chart could use an update. I'm looking for a new compound for heavy cutting duty and it's hard to discern similar products.
I've been using Menzerna for a while and I love FG400 and SF4000. I also use SHCC300 on a regular basis (I see some pretty hammered vehicles) and have been looking to try something similar.
What I find interesting is that FG400 and SHCC300 are both a 10 on the chart while I've found the difference in cut is significant. Often I find myself leaving FG400 on the shelf because I would need to compound each section twice to remove all the defects. With SHCC300 and a wool pad nearly every defect comes out with ease.
Also I'm confused as to why M101, M100, and M95 are all in the same column as well. I haven't used them all but from what I've read they offer significant differences in cut as well.
Any suggestions for products similar to SHCC300 (long working time, super heavy cut, low dusting, finishes well enough to 2-step)?
Because I recently became an OC Pro installer I've been looking into the Hyper line but the chart says its only an 8 compared to FG400 at a 10. Am I going to have to stick with SHCC300 for heavy cutting duties or is there something else I should try?
I realize I asked the same question 3 times but whatever haha.
Thanks in advance!
Finishing Touch Auto (Stayton, OR)
Ryan Hendricks (Owner) 503-602-8483
FTA Website
Re: Heaviest Cut Compound?
Listen SHC300 is why your floors are slippery I'm on to you guy.
(Lmao sorry to funny couldn't pass it up)
3000 grit foam finishing discs are your next step
I've seen this in some pictures and videos but haven't actually considered wet sanding the really beat up vehicles. Maybe I'll have to make a thread about that. I'll just threadjack my own thread haha.
Who here does wetsanding regularly as part of the correction process?
Does this take off more or less paint than just compounding?
Does it save time?
Do you get better results because of the reduced orange peel?
FTA Website
I'd be very cautions about doing or offering wet sanding for customers with factory paint.
I taught the first public class at Mobile Tech Expo on this topic when Meguiar's introduced their Unigrit Sanding/Finishing Discs back in 2010 and gave this same caution back then.
Factory clearcoats are thin. Here's the deal. Sure you can sand them and buff them and if you're good and do everything right there won't be a whoops!.
It's down the road that can be the problem as now the car will be exposed to the sun, wear-n-tear, wet weather, future detailing and now the factory thin paint is now even thinner.
I know you already know this stuff so this is mostly for all the people that will read this thread into the future.
Be careful.
It's too bad car manufacturers don't spray more clear paint on their cars in the first place.
Now if you're working on a custom paint job that's a whole other story.
What mike said, however sometimes there's a must if I'm working on a rock hard clear and getting no results and I'm going to have to do multiple passes.
I am going to wetsand with 3k.
Also I consider it safer , as running with a heavy cut pad and compound can introduce a lot of heat, sometimes I'm more comfortable with sanding then actually going to town with just compound.
3k sand marks are easier to get out then regular scratches and swirls.
http://www.autogeekonline.net/forum/...ad.php?t=98051
There is a thread I wetsanded a oxidized truck it would have taken me forever to buff that junk away.
Also it depends on how much your getting paid, what kind of car it is, and how good you told the client its going to come out.
I wouldn't wetsand a 2013-16 car as its to new unless it is hammered and needs it.
Many variables come into play and just use common sense.
Another thing I wouldn't wet send a whole car for 3-600$ it still takes time to sand.
So make sure your getting paid properly
Originally Posted by RPM_BR
3D AAT Rubbing Compound
I been wanting to try that stuff, how do you like it
What machine and pad are you using? I tried it and didnt think it was anything great...
I found that using Lake Country's Thin Foamed
Wool Pads with heavy-cut compounds...even with
some of the ones you mentioned in your OP...
gave excellent paint correction results.
OTOH:
3M has a few heavy-cut compounds
that just might pique your interest.
Here are a couple of them:
•Perfect-It 3000 Extra Cut Compound
•Super Duty Rubbing Compound
By bmwstephen in forum Auto Detailing 101
Last Post: 06-07-2015, 06:51 AM
By zlman in forum Auto Detailing 101
Last Post: 08-02-2013, 08:28 PM
By 05RLS2 in forum Products Guides
Last Post: 07-26-2011, 12:40 AM
Last Post: 12-17-2010, 08:09 AM
By BlackRocks in forum Auto Detailing 101
Last Post: 06-01-2006, 01:21 PM
