Restoring/maintaining rubber window seals
I don't want to just re-blacken the rubber around my car's window as a dressing would but is there a product that would re-nourish and maintain the softness/moisture, sort of like a "lotion."
The rubber is still in good condition but want to start maintaining it before it's too far gone and replacement is the only option.
Re: Restoring/maintaining rubber window seals
gummi pfledge
get it now, before it's gone
This is the best plan of attack, that is start taking care of these surfaces while they're still in great condition instead of letting them go to the point of replacement and then trying to find a miracle product to try to safe them.
See what I wrote in post #4 here,
http://www.autogeekonline.net/forum/...ml#post1317746
Besides that,
"Find a product you like and use it often".
Here's a product you can use for rubber window seals plus your tires and trim... this stuff really works great.
Review - NEW BLACKFIRE All-In-One Trim & Tire Protectant
A few months ago Nick came to me and says,
"I have this new product for you to test out, it's an all-in-on tire and trim dressing"
I think, ho-hum... just another tire and trim dressing. Then I start using it. And using it. And using it.
This product is freaking awesome!
Why?
Because it cleans, conditions and protects in one step.
While that might not sound like rocket science most trim dressings require you to FIRST clean the trim. Most tire dressings require you to FIRST clean the tires.
Not so with this product. Simply have a few extra microfiber applicators, towels and brushes handy to work, agitate and wipe-off any excess and going from dull and boring to WOW is fast and easy.
Plus since it's an all-in-one product you save money since you don't need any dedicated cleaning products.
2012 Chevy Traverse - Cosmetic Engine Detailing
At our last detailing boot camp class we teach two types of engine detailing.
Full engine detailing - That's where you use an engine degreaser and actually wash out the engine bay using running water.
Cosmetic engine detailing - This is where you simply blow-out the engine compartment with air and then wipe the engine compartment down using some time of dressing. I let my class use the new NEW BLACKFIRE All-In-One Trim & Tire Protectant to do cosmetic engine detailing to this 2012 Chevy Traverse.
Before
After
Before
After
It works GREAT for doing cosmetic engine detailing and the above took less than 15 minutes!
If you're simply working on your own cars you can include this as a part of your Saturday wash and wax and get it done fast.
If you're detailing for money, then adding cosmetic engine detailing as an upsell is a money maker.
1956 Chevy Bel Air Convertible
Here's the whitewall tires on a classic 1956 Chevy Bel Air Convertible.
Wipe on and agitate using a microfiber applicator pad
Wipe off the excess....
DONE!
Quick, easy and the results are beautiful!
Ugly to beautiful - The tires on a 1932 Ford Phaeton
Same detailing boot camp class, here's a 1932 Ford Phaeton that we used to teach how to use Steam Cleaners to do interior cleaning as well as machine polishing to remove the swirls.
The tires were dull and lifeless until we took BLACKFIRE All-In-One Trim & Tire Protectant to them with a simple wipe-on, wipe-off.
Before
After
While I'm a HUGE fan of the DP Tire Coating Kit there are some times when it's not practical to do a dedicated tire scrubbing, (scrubbing till the tires are completely stripped of all previously applied tire dressings), and for projects where it just doesn't make sense to do the steps required to apply a coating to the tires this is the next best thing.
Not just because it's fast and easy but because the results are simply phenomenal.
It's now our go-to product for cosmetic engine detailing, plastic trim restoration and cleaning and dressing tires in one-step.
Get some. Use it. Like it.
On Autogeek.com
Microfiber Applicator Pads
Microfiber All Purpose & Wheel Detailing Towel
For those of you that want more information, here's the product description from the website.
BLACKFIRE All-In-One Trim & Tire Protectant Cleans, restores, protects and beautifies exterior plastic trim and tires. Built-in cleaners remove embedded dirt from tires, including white walls. Use on tonneau covers, engine compartments, and plastic moldings. Dries to the touch – will not sling. BLACKFIRE All-In-One Trim & Tire Protectant will quickly become the most used – and arguably the most versatile – detailing product in your garage!
BLACKFIRE All-In-One Trim & Tire Protectant is far more than just another trim protectant or tire shine. Formulated with a blend of cleaners and degreasers, All-In-One Trim & Tire Protectant removes grease and grime while beautifying the surface with a low-gloss, satin sheen of protection. Water-based formula will not attract dirt or dust.
BLACKFIRE All-In-One Trim & Tire Protectant can be used to clean and protect the following automotive surfaces:
Tires – including white walls
Engine compartments
Tonneau covers
Running boards
Plastic trim
Door moldings
Grilles
Mud flaps
Bumper protectors
If you’re a frequent user of rinseless and waterless washes, BLACKFIRE All-In-One Trim & Tire Protectant will quickly become your favorite detailing product. Because this versatile formula features built-in cleaners, there is no need to use a messy tire cleaner and scrub brush before applying your favorite tire shine; BLACKFIRE All-In-One Trim & Tire Protectant does both! Your tires will be left clean and shiny – apply with a microfiber applicator for best results.
BLACKFIRE All-In-One Trim & Tire Protectant is perfect for classic cars with white wall tires and pick up truck tires with raised white lettering. Now you can clean and shine your white walls tires at a car show – no water or dedicated white wall tire cleaner is required.
Frequent car care is easy car care with BLACKFIRE. Applying a coat of BLACKFIRE All-In-One Trim & Tire Protectant onto your vehicles plastic, rubber and vinyl exterior surfaces once a month will ensure they do not fade or discolor over time. A little bit goes a long way, so a single 20 ounce bottle will easily last 6 months or more.
Thanks ronkh57 and Mike.
I'm looking for a product that not just coats the surface but can work itself down below the surface and restore some of the properties of the rubber and not need to be used frequently but only once or twice a year.
Gummi Pfledge looks like something to that effect. I'l order some from AG. Thanks.
Gummi Pfledge is an effective maintenance material. I apply it 3-4 times per year. Works great!
By nakranij in forum Auto Detailing 101
Last Post: 04-19-2021, 07:46 PM
By SixZee in forum Auto Detailing 101
Last Post: 09-28-2019, 12:47 PM
By gsmarquis in forum Auto Detailing 101
Last Post: 06-30-2018, 08:06 AM
By chaznad in forum Ask your detailing questions!
Last Post: 03-15-2017, 11:50 AM
By roscoe in forum Ask your detailing questions!
Last Post: 01-17-2010, 08:00 PM
