Page 1 of 2 12 LastLast
Results 1 to 10 of 12
    Nov 2015
    Issue with 1Z Gummi Pflege?
    Does anyone know if the foam applicator is supposed to be removable?
    McKee's 37 Product Support
    Jan 2011
    7,265
    Re: Issue with 1Z Gummi Pflege?
    Quote Originally Posted by truzoom View Post
    Nope, that's not normal. Because you apply pressure as you use it, the foam head should stay on during use. Just try not to lose it.
    Super Member AnthonyGXP's Avatar
    Nov 2014
    390
    I would certainly take the opportunity while it's removed to clean and rinse out well. If you have trouble keeping it on, you could try a small bit of glue to reattach after the foam has been cleaned and dried. Just be sure not to glue around plunger where product is dispensed.
    You could also keep it removable to be easily cleaned after each use.
    Super Member dcjredline's Avatar
    Mar 2012
    Upstate NY
    3,340
    Mine did that too. It wont stay on while applying anymore. I havent tried to glue it back on but I was very disappointed.
    "Dirt likes detergent so much better than the surface that it's attached to, it'll leave that surface to go hang out with the soap"...aim4squirrels
    Mar 2011
    PA
    5,793
    For sure it does wear and fall off. I just dispense it on a small towel now. :-
    2018 Colorado ZR2
    Super Member Chris@AutoCleanse's Avatar
    Nov 2012
    St. Cloud, Florida
    1,551
    Same here, mine also fell off. Just put on an applicator and apply.
    Super Member ScottB's Avatar
    Mar 2006
    South Florida
    18,803
    Mine came off also ... and I found it to be a bit of a benefit. I can use it on my finger to protect weather-stripping that is not flat. I wish I had a couple of these round foamy things as it actually came in handy.
    Scott
    Super Member spazzz's Avatar
    Jan 2014
    Madison
    1,013
    Mine fell off awhile ago. I resorted to a 1" foam poly brush and found it much easier to use.
    Just hit the plunger against the brush and load it up. The chisel point allows more accuracy.
    Apr 2010
    Washington DC area
    338
    Mine keeps falling off too - great stuff so.
  10. #10
    May 2010
    Colorado Springs, CO
    466
    Quote Originally Posted by spazzz View Post
    Now that is a great idea. Thanks.
  1. Einszett Gummi Pflege
    By cib3k in forum Auto Detailing 101
    Last Post: 01-04-2016, 04:39 PM
  2. 1Z Gummi Pflege on exterior rubber?
    By 05RLS2 in forum Auto Detailing 101
    Last Post: 03-07-2011, 01:36 AM
  3. Gummi Pflege and Ignorance.
    By fancyfootwork in forum Off-Topic
    Last Post: 06-28-2010, 10:52 AM
  4. Alternatives to Gummi Pflege?
    Last Post: 01-15-2010, 08:36 PM
  5. Gummi Pflege and detailing...
    By Rento in forum Auto Detailing 101
    Last Post: 06-28-2008, 08:42 AM
