Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Oct 2015
    66
    2 Bucket Wash vs. Foam Gun + Rinse Bucket
    I've been using the 2 bucket wash technique, but was thinking about getting a foam gun. I saw a video online where the person started with the 2 bucket technique, but then used a technique where they fired the foam gun into the wash mitt as they washed. It seemed like the wash bucket was unneeded in this case. Any opinions on whether or not you even need a wash bucket if you use a foam gun like this?
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    Re: 2 Bucket Wash vs. Foam Gun + Rinse Bucket
    It seems that now there are endless variations of
    car-washing methods---I've heard them called:
    "hybrid" car-washing methods.
    IMO:
    It boils down to what method each individual finds
    works best for them. (Sometimes it even depends
    on the area of the World in which they live.)
    Super Member parshooter's Avatar
    May 2015
    Lewis Center OH
    626
    Isn't the point of the foam gun to get the car super foamy? If you're just foam gunning the mitt, that seems a waste of the foam gun's purpose.
    Super Member AnthonyGXP's Avatar
    Nov 2014
    390
    Quote Originally Posted by parshooter View Post
    By using this method, which I have, I will still foam the car and then use the technique mentioned above for the remainder of wash. Thus eliminating the use of the soap bucket.
    It's the exact same soap/foam that would be in your bucket, so not sure where you see this is wasteful?
    Dec 2010
    Ohio, USA
    21,057
    Interesting...
    If the foam gun's purpose is to get a car super foamy,
    then what exactly is the foam's purpose?
    Aug 2010
    New Jersey
    15,349
    If I use a foam gun, I do not use a wash bucket, rinse bucket only.
    Mar 2011
    PA
    5,816
    The idea of the foam gun is to pre soak and loosen any dirt before the wash. Everyone does it a little different. My method.
    1. Wheels/tires first
    2. Rinse xterra with water
    3. Foam up with the gun (gilmoure)
    4. Wash with griots bucket filled with soap (same as gun)
    5. Rinse
    6 Flood rinse
    7. Dry
    2018 Colorado ZR2
    Super Member Paul A.'s Avatar
    Dec 2007
    Tampa Florida
    5,274
    +1. I use 2 rinse buckets, one on each side of the car. I use only as much soap in my gun to wash the vehicle but with an eye towards conserving as much soap as possible...simply a cost factor. Not stingy, just frugal.
    And that's not saying that a squirt from the gun into the now clean mitt for the next section is wastefull, i just like knowing the paint is covered in soap that i'm going to clean. Basically, i like getting the surfactants working first before i wipe.
    Oct 2015
    66
    I guess I could clarify, in the video, they did foam the entire car. But after foaming it, as they wiped with the mitt they shot more foam in front of the mitt as they wiped.
    I wasn't saying to just spray foam into the mitt and then wiping it on the car, although that would work too, but probably would be a waste of a foam gun.
  10. #10
    Oct 2015
    200
    I did this the other night, and i really didn't feel like it is something I would do again. I needed to do a quick wash and didn't have too dirty of a car (but too dirty for Rinseless or Waterless).
  1. foam gun wash dry then 2 bucket method?
    By Newcarsmell in forum Auto Detailing 101
    Last Post: 09-02-2019, 01:48 AM
  2. Replies: 15
    Last Post: 07-28-2013, 05:42 PM
  3. If using a foam lance, is it necessary to use a wash bucket?
    By AliMusa in forum Auto Detailing 101
    Last Post: 05-08-2013, 08:28 AM
  4. Clean rinse bucket.
    By Luke in forum Off-Topic
    Last Post: 01-03-2007, 07:23 PM
