Results 1 to 9 of 9
    Super Member Crispy's Avatar
    Jun 2013
    779
    New Paint, Wet Sanded and Polished
    Project Description #27 Paint Passenger Side Lower Molding
    New molding had no coating at all and was dull grey plastic.
    Needed to paint to match body color.
    Spread out over 2 day weekend for painting stage 2 left fully flash between coats.
    Material used
    Automotivetouchup Adhesion Promoter
    Automotivetouchup WA528F Base Coat Dk. Bronzemist Met.
    24042 Dominion Sure Seal High Gloss Instant Clear Coat
    Dupli-Color Dark Grey Sandable Primer
    Bondo Glaze Putty
    400 grit wet/dry sandpaper
    800 grit wet/dry sandpaper
    1500 grit wet/dry sandpaper
    2000 grit wet/dry sandpaper
    Orange LC Cutting Pad
    Optimum Compound II
    White LC Polishing Pad
    Optimum Polish II
    Blue LC Polishing Pad
    Optimum Finish Polish
    Optimum Gloss Coat
    Procedure
    Prep
    Sand complete with 400 grit wet/dry sandpaper
    2 light coats Automotivetouchup Adhesion Promoter
    3 light coats Dupli-Color Dark Grey Sandable Primer
    Sand defects 800 grit wet/dry sandpaper (2 defect rear section-original OEM defects)
    Filled defects with Bondo Glaze Putty
    Sand Glaze Putty over defects 400- 800 grit wet/dry sandpaper
    (took a lot of sanding and still not 100%)
    Spray defects with Dupli-Color Dark Grey Sandable Primer two light coats
    Final sand defects with 800 grit wet/dry sandpaper
    Paint
    3 coats Automotivetouchup WA528F Base Coat Dk. Bronzemist Met.
    (used 1 complete 16oz. can of paint)
    3 coats 24042 Dominion Sure Seal High Gloss Instant Clear Coat
    (used 1 complete large can of paint)
    Finishing
    Test panel starting with 2000 grit to identify "Orange Peel"-view from different angles
    Test panel with 1500 grit to remove "Orange Peel"
    Buff with PC with 4" Orange LC Pad and Optimum Compound II speed 5 (remove sanding scratches)
    Sectioned off test area and just buffed the unsanded portion to see if noticible difference
    (definite difference in shine and depth of colour between sanded and not sanded)
    Sand out "Orange Peel" complete with 1500 grit (three coats of fresh Clear Coat to work with)
    (took over an hour to do and mistakenly used 800 grit on small section and had to finish up with 1500 grit)
    (could have used 800 grit on whole thing and then gone back over with 1500 as final step)
    (a bit tricky using the PC and 4" pads but need the coverage area and power for cutting)
    Polish with PC with 4" White LC Pad and Optimum Polish II
    Final Polish with PC with Blue LC Pad and Optimum Finish Polish
    Sealing
    Optimum Gloss Coat
    Aug 2015
    45
    Re: New Paint, Wet Sanded and Polished
    Pictures?
    Jun 2013
    779
    Will try tomorrow-hard to get picture as is 8ft long and usually to dark when I get home from work.
    Jul 2015
    165
    I wouldnt seal it until it has had a chance to off gas. When I worked in a paint shop, we told customers to wait 3 months before using a sealant or wax
    Jun 2015
    920
    Seriously, Pretty Pretty Please add some pictures
    Jun 2013
    779
    Pictures as best I could do. I will wait on the Gloss Coat as long as weather permits (definitely have to get on before the snow flies).
    Attached Thumbnails Attached Thumbnails New Paint, Wet Sanded and Polished-dscn1219-jpg   New Paint, Wet Sanded and Polished-dscn1220-jpg   New Paint, Wet Sanded and Polished-dscn1221-jpg   New Paint, Wet Sanded and Polished-dscn1222-jpg   New Paint, Wet Sanded and Polished-best-shot-dscn1224-jpg   New Paint, Wet Sanded and Polished-dscn1223-jpg   New Paint, Wet Sanded and Polished-dscn1225-jpg   New Paint, Wet Sanded and Polished-dscn1226-jpg   New Paint, Wet Sanded and Polished-dscn1227-jpg
    Jun 2013
    779
    Pictures of the molding on the vehicle.
    My picture taking skills could use some upgrading.
    Attached Thumbnails Attached Thumbnails New Paint, Wet Sanded and Polished-pass-lower-molding-car-sdc10027-jpg   New Paint, Wet Sanded and Polished-pass-lower-molding-car-sdc10028-jpg
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    Looks pretty good to me.
    Sep 2015
    6,281
    Now that's a process
  1. Advice needed. Using Meguiars no 7 Glaze on wet sanded paint?
    By James Dean in forum Ask your detailing questions!
    Last Post: 06-15-2017, 02:57 PM
  2. 350Z Tinted tail lights- wet sanded/polished/sealed
    By JoeKhoda in forum Show N' Shine
    Last Post: 10-25-2013, 11:25 PM
  3. Sanded through clear coat - touch up paint help
    By Dorian in forum Auto Detailing 101
    Last Post: 09-12-2013, 01:25 PM
  4. '71 BMW 2002 Repaint, Wet Sanded and Polished
    By Detailing by M in forum Show N' Shine
    Last Post: 07-15-2013, 11:52 PM
  5. just had my new paint wet sanded and buffed. few ???
    By crazyelf in forum Wet-Sanding, Cutting & Buffing
    Last Post: 05-22-2011, 01:26 AM
