D114 dilution?
I think the bottle says 1 to 128 (1 oz per gallon)
Is there any problem using this ratio for rinseless wash when the car is pretty clean? (like easier to streak or harder to buff off)
I have seen the 1:256 posted a lot for lightly soiled cars, is there any problems doing 1:128 anyway besides using more product. I wanted to be on safe side of having a more lubricated wash solution especially for the lower sides of the car.
Also, I wasn't able to purchase too many pieces of high end MF towels, they cost too much and I wanted to try them out, so I got 5. Does it make sense to use the nicer 5 for horizontal panels and then try to get away using cheaper grade MF on the doors?
Thanks
Re: D114 dilution?
I like to use Meguiars D114 at
-1:100 for waterless
-1:200 for rinseless
With right technic and defect free microfiber, it should be fine.
Re: D114 dilution?
1:128 is fine as long as product usage isn't an issue for you. 1:256 works fine unless car is very dirty. What I do...I pre-spray the panel with 1:128 and follow up with the normal rinseless procedure at 1:256.
Re: D114 dilution?
What do you mean "product usage," silverfox? Running out of it quicker?
How many do rinseless washes at 1:128 rather than 1:256?I'm one to ere on the side of making sure the surface is well-lubricated, but I don't want that to translate into streaking and excess buffing.
Perfection is attained by slow degrees; it requires the hand of time. (Voltaire)
2013 TESLA MODEL S | Gyeon Syncro | Gyeon Cancoat
Re: D114 dilution?
I do rinseless w/D114 @ 1:128👋🏼
I don't have a problem with it streaking or being difficult to dry.
Re: D114 dilution?
5 towels folded in 4s is 20 clean sides of towel...if ur car isn't very dirty anyway that should be MORE than enough towels. That 1 wipe per side of towel is major overkill IMO. 1/256 is the ratio I use too and I also pre-soak with 1/128
Re: D114 dilution?
You could only prove that to me by going outside and taking a close-up picture, in the Sun of the car you use this method on.
You are going to wash a load of towels anyway...why use the "Skimp & Swirl Method"?
Re: D114 dilution?
That's my rationale. The towels have one purpose: my car. Going in the washer one way or another sooner or later!
(Sent via my mobile device)
Re: D114 dilution?
Might be. But, it's no skin off my back and I spend no time cleaning the towel or reintroducing it back into the solution.
Re: D114 dilution?
rinseless wash when the car is pretty clean?[
No...none whatsoever.
After folding "the nicer 5"...
RE: http://www.autogeekonline.net/forum/...ber-towel.html
Try using the resulting 40 sides first, before
trying to get away with cheapening out.
By kuji in forum Auto Detailing 101
Last Post: 11-26-2016, 11:14 AM
By SwiftTone in forum Auto Detailing 101
Last Post: 03-28-2016, 10:11 AM
By TheAverageMan in forum Auto Detailing 101
Last Post: 04-08-2015, 12:30 AM
By BTLew81 in forum Auto Detailing 101
Last Post: 12-11-2014, 01:43 PM
By creaky in forum Auto Detailing 101
Last Post: 09-13-2014, 05:20 PM
