Orange peel
Okay, my friends at AGO,
My vehicle is gorgeous, beautiful thanks to Colli 476. Unfortunately the painters did not do a fabulous job, yes I'm afraid she has orange peel. I won't do anything due to comprimising the surface. I know there are pads to try and correct this but I don't wish to take that route. That leads to my question. Do you think that with normal correction the peel will
subside due to eventual correction? Thanks and take care.
Peace,
Darrin
Re: Orange peel
I doubt it. Was this a complete re-paint?
Re: Orange peel
No, original. You don't think that eventual correction will do the same as those pads?
Peace,
Darrin
Re: Orange peel
Before you try to do any orange peel removal it would be worth it to have the paint thickness measured. Factory applied paint is so thin these days that on some cars trying to remove even just the high spots of the orange peel will make the clear portion of the paint so thin that your paint could start failing in just a couple of years.
There are quite a few threads on here that discuss paint thickness and what type of safety margin to try and maintain.
But if you had a new paint job on the car then it would be much easier to sand down the clear to eliminate all the orange peel. Painters will generally apply several times (or more) clear than does the factory.
Re: Orange peel
Yeah, thank you for the response. I really have no problem leaving her like she is. Who doesn't want show room paint? It's original paint and she's beautiful as she is. Thanks.
Peace,
Darrin
Re: Orange peel
Peace,
Darrin
I had a 04 G35 that I used every compound and polish under the sun with rotary and DA. Paint became thin (75 mic) after years of buffing. And yes, some of the OP became much less noticeable, but it took years of buffing.
Re: Orange peel
Generally speaking, no - traditional pads will not level orange peel over time. They are soft enough to move with the peaks and valleys of the orange peel - and therefore you will see consistent paint removal at the tops and bottoms of the peel.
Pads for removing orange peel (like denim) and significantly stiffer than other pads, and that's so they don't conform to the valleys. They only remove the peaks.
Re: Orange peel
Thank you all. Pretty much what I expected. She still shines like a MF. That Colli 476 is a fantastic wax if y'all haven't tried it. Take care and good luck to ya.
Peace,
Darrin
Re: Orange peel
MicroFibers don't shine!
"The first gulp from the glass of natural science will turn you into an atheist, but at the bottom of the glass God is waiting for you." --Werner Heisenberg (Pioneer of Quantum Mechanics, Nobel laureate Physics)
By Markdishaw in forum Ask your detailing questions!
Last Post: 05-18-2020, 10:27 AM
By parttimer in forum Auto Detailing 101
Last Post: 08-14-2015, 06:48 AM
By builthatch in forum Ask your detailing questions!
Last Post: 01-17-2015, 05:09 PM
By tguil in forum Ask your detailing questions!
Last Post: 02-02-2013, 09:47 AM
By crash73 in forum Auto Detailing 101
Last Post: 07-04-2007, 09:24 AM
