Re: Need some help correcting Civic
If i were going to attempt a layer it would be M26.
Did you wipe it before you waxed with ipa or anything? I reserve ipa wiping for test spots to make sure it's not fooling me that I had correction.
Once I get the right process I don't wipe after I'm done polishing with ipa, just microfiber. The oils are in it for a reason. With that said if I was going to apply cquartz or a sealer like 111 I would for bonding.
yes after polish i used carpro eraser..how is 885 in terms of durability and looks..debating between 476 and 885 ..i am planning on using it for winter prep..
476 & 885 are the same product
i c..then whichever is cheaper i will get that and topped it off with 915 i think it might work..protection and looks.
If i were you I'd just keep the 915 as my topper and put a sealant on first. Duragloss 111 is like $10.
The only reason I have two collinite products is one is a liquid. They smell almost identical.
Add something wowa to have for winter if you need a refresh like optiseal
If you want pop and the deep wet look try putting on a glaze like PoorBoys World Black Hole. It will add depth to the color. You use a light polish/finishing pad on low speed. Then seal and wax.
Originally Posted by Nix
try applying more pressure (not enough to bog it down nor let it spin to freely but right in the middle) with slow overlapping passes so you can let the pad and polish/compound do it's job...
By DETAILROOKIE in forum Auto Detailing 101
Last Post: 11-26-2017, 03:04 PM
By SonataLF in forum Auto Detailing 101
Last Post: 02-16-2017, 09:13 PM
By fejcharson in forum Auto Detailing 101
Last Post: 10-06-2015, 06:52 PM
By Jaretr1 in forum Show N' Shine
Last Post: 02-22-2011, 04:23 PM
By Harrison in forum Auto Detailing 101
Last Post: 02-03-2009, 06:30 PM
26 | 27 | 28 | 29 | 30 | 31 |
