Pin Holes
I just finished using a Nanoskin mitt for the first time. It is a lot faster than clay and did a great job. I washed the truck first and then wiped it down still wet with the mitt and a bucket of Nanoskin Bubble Bath. It now passes the baggie test! Tomorrow it is on to Klasse AIO and Klasse SG ( at least 3 coats ). It should make the blue streak pearl coat really pop on this 2014 Ram R/T. When I was squeezing the Nanoskin mitt after rinsing I noticed water squirting out of small pin holes in the tacky side of the mitt. Is this normal for the mitt? I loosely rolled the mitt tacky side out to squeeze some of water out before air drying. Did I just ruin the mitt? I sure hope I didn't as it isn't cheap and was a gift.
Re: Pin Holes
This always concerned me also but it should be fine
Steve -The Titanic Was Built By Professionals But The Ark By Amateurs- "Boanerges"
Re: Pin Holes
No, nothing wrong with the nano mitt. Mine did the same thing and is still rockin' after maybe 30 uses. One thing i like to look at is the integrity of the rubberized "grabby" side. I like to keep it clean after each use. Mine has developed some cracks here and there but as long as it's clean it's still working fine.
You're fine.
Re: Pin Holes
Whew! Thanks a lot guys. Now to finish up the AIO with the DA and then my favorite part layering on the SG using the method "klasse" ( thank you! ) posted a couple years ago. Once I read his post I've never looked back, it looks like "candy" and is easy with his method!
By Emt1581 in forum Auto Detailing 101
Last Post: 05-15-2019, 03:40 PM
By Kealokian in forum Ask your detailing questions!
Last Post: 02-26-2014, 12:09 PM
By statusdetailing in forum Off-Topic
Last Post: 10-22-2013, 03:28 PM
By RRocket in forum Auto Detailing 101
Last Post: 05-13-2010, 09:51 PM
By emaxxman in forum Auto Detailing Tools and Accessories
Last Post: 07-22-2006, 06:06 AM
26 | 27 | 28 | 29 | 30 | 31 |
