Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Mar 2015
    Sunscreen on paint
    Hi guys,
    I just got back from the beach and I found that I've got marks on my roof from sunscreen that was on my arms. It was from loading/unloading paddle boards. My paint did have a coat of wax on it but now the finish looks dry or dull in a few places. How should I start with correcting the spots? I've read to use a citrus cleaner or clay bar. Any other ideas?
    Apr 2014
    WI
    125
    Re: Sunscreen on paint
    I would try some wax prep soap (something like dishsoap) then rewax that area.
    17 Land Rover Discovery: Fuji White; 07 Land Rover LR3 SEV8 4WD: Java Black Micatallic; 18 Jeep Wrangler JLU Sahara: Black; 05 Jeep Liberty Limited 4WD: Light Khaki Metallic
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    Sunscreen is one of the products that has what I call
    actual Nano-particles (usually less than 100nm in size)
    in its formulation:
    Titanium dioxide (TiO2); grayish/whitish-looking stuff.
    Unfortunately, for vehicles (the Jury is still out
    on how Humans are affected):
    These Nanos will be small enough to penetrate
    vehicles' paint-systems---and the longer they're
    not removed/wiped-off the paint: the possibility
    of deeper, and deeper penetration exists.
    I'll suggest to first try an AIO.
    Then if needed: Move up to the more
    dedicated polishes/compounds.
    Note:
    I've seen the imprints of sunscreens "come back"...
    even after a complete wet-sanding process.
    Only a re-spray completely corrected the issue.
    Hope that's not the cure for your situation.
    Good Luck in your efforts!
    Mar 2015
    Thanks for the suggestions. I'll report back after I try a few things this afternoon. I'll keep my fingers crossed!
    Super Member Dr_Pain's Avatar
    Nov 2012
    South Central, Louisiana
    2,196
    what Bob said!
    https://www.facebook.com/FlawlessFinishDetailing
    Dr. Claude Tremblay, Co-owner/Senior Detailer, Certified CQuartz FINEST Installer
    May 2014
    259
    in its formulation:
    Titanium dioxide is now being used as a new treatment for window glass because it attacks and degrades anything that touches it, thereby helping to keep windows clean.
    Geek link: https://www.youtube.com/watch?v=UgbT2fJTqFY
    Mar 2015
    Would clean up of a zinc oxide based sunblock be the same as titanium dioxide?
    Jun 2015
    Wow very cool!
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    Mar 2015
    From what I can see...I was able to remove the spots last night. I cleaned the area, tried the clay bar and a spray polish but none of those efforts made the spot look any better. I ended up polishing by hand with meguiars ultimate polish this helped a lot but I could still see an outline of the spot so I continued with the same polish with the DA polisher. After a few passes, I couldn't see any imperfections. I followed up with liquid wax. Hopefully the spot won't come back.
    **Bob - How long did it take for the spots to come back on the vehicles you've worked on?
  10. #10
    Dec 2010
    Ohio, USA
    21,057
    Quote Originally Posted by cb242 View Post
    That's good news!
    Thanks for the follow-up...
    Usually around 3-4 months.
    But I can only conjecture that was where enough of the
    sunscreen had originally been left on the vehicle long
    enough to where it had penetrated the CC, and then
    down to/into the BC.
    By attacking your sunscreen issue in a timely manner,
    hopefully that amount of penetration did not/will not
    occur with your vehicle.
  1. How can I remove white hand/finger prints left by my sunscreen?
    By dpruiett in forum Ask your detailing questions!
    Last Post: 08-08-2017, 03:46 PM
  2. Sunscreen on cloth interior
    By mills3 in forum Auto Detailing 101
    Last Post: 12-16-2015, 12:01 PM
  3. How to remove old sunscreen on leather
    By Hokie335i in forum Auto Detailing 101
    Last Post: 08-12-2014, 11:53 AM
  4. Sunscreen stain on interior black plastic
    By elk42 in forum Auto Detailing 101
    Last Post: 08-07-2011, 12:02 PM
  5. Sunscreen on leather
    By Jonathan_Hubbs in forum Auto Detailing 101
    Last Post: 07-21-2011, 04:52 PM
