Re: Engine bay dressing-- what do you use?
Originally Posted by
bolts
can you use 303 by spray and let it sit without wiping or does it have to be wiped dry? i think i read that it needs to be wiped dry.
304 Protectant must be buffed dry, or else it will remain greasy and attract dirt.
Here’s Carpro Pearl at 3:1 using 2 coats. durability is only about 2 months though.
I've used everything from Griot's Garage Engine Bay Dressing (GREAT product), 303 protectant (how can you go wrong) and just got VRT which I've heard great things about, will go down to the garage at halftime of the Hotspurs and Man U game in a bit and apply some, thanks to this thread.
2022 Elantra N Cyber Gray
Breese147
Sent from my iPhone using
Autogeekonline mobile app
is perl spray and walk away or do you have to wipe dry?
bolts
I get more even coverage by lightly wiping leaving a bit of excess so it absorbs in. I do however use it under wheel wells by simply spray on and walk away and it works fine.
Hyper dressing is hard to beat. Super inexpensive and always produce great results. But, anything water based is probably ok. As long as it dries without causing stains, you can use it.
I guess I'm the odd one here.
I use a fine mist sprayer, mf towel and a blower. 1-2 minutes and done.
Products? I have most of the products mentioned here and honestly it hasn't made much of a difference (it's hidden, out of the weather.). I typically use what I didn't like on the exterior (with the exception being I don't use gel like products there).
I've used the [older] Blackfire All in One Trim & Tire Protectant.
at two months, it was dusty, but still looked pretty good. I last checked around end of November.
My Sonus motor kote will be here tomorrow for the lazy spray
Anything plastic I just use Wolfgang exterior trim sealant because I know it lasts
