Inside door handles
The most scratches are in door handle cutouts... Caused by fingernails.
How do you folks get these out?
Re: Inside door handles
I used Meguiars Ultimate Polish on a hex hand applicator. I jammed it under the handle and scrubbed back and forth and up and down.
Took about 10-15 minutes each.
Much like Riff, I use an old paint stick, a cut piece of an old, now retired orange LC pad wrapped in a MF towel. Depending on the level of marring and the paint hardness/softness, i alter my polish product accordingly. This technique helps me get into the area and not cut too hard. I say that but i will admit to breaking the paint stick at times due to exerted pressure!
I will also admit...it's a "one step" effort for me. Trust me, it WILL get all scratched up again! Plus, like Riff said, it doesn't take too long to clean up.
I use a compound or polish and a MF towel wrapped around my finger tip and scrub away! Usually works great
This ^^
If i have an old pad (LC Orange usually) i will cut it up into pieces and use it there. works like a charm.
Owner at Clean N' Shiny Auto Detailing Inc.
Same here, and I noticed that if you continue in those areas and also make sure you apply a good LSP there the scratches don't come back as quickly...or maybe it's just because I've learned not to let my nails rub against that area when I open the door
Magic eracer will remove most of it in seconds. Then just use polish on a hand applicator to finish it up.
Ask and you shall receive! Again, Mike Phillips comes through.
https://www.youtube.com/watch?v=SMsNg1iCoTU
"How to buff out concave and concave panels by machine". In this demo he uses a Porsche 911 and shows how to get inside the door handles.
By DetailKitty in forum Tricks, Tips and Techniques
Last Post: 04-17-2017, 10:05 AM
By asalesagent912 in forum Off-Topic
Last Post: 06-19-2014, 10:42 PM
By Largebore in forum Auto Detailing 101
Last Post: 06-29-2012, 08:05 PM
By Wasaabi in forum Auto Detailing 101
Last Post: 06-04-2012, 12:37 AM
By Hades02 in forum Auto Detailing 101
Last Post: 04-21-2009, 05:40 PM
