Browning tire
I'm having a hard time getting the brown out. I used up my turtle wax tire cleaner. Started using megs super degreaser. Do you have to wipe them down a hundred times. They're being stubborn
Re: Browning tire
I used to have that issue, until i started to use a water-based tire shine. Poorboy's Bold and Bright tire shine has some Vitamins in it which has stopped the brown-ing on my tires. I've been using it for years without issues.
Owner at Clean N' Shiny Auto Detailing Inc.
Re: Browning tire
![Quote](https://www.autogeekonline.net/forum/images/autogeek/misc/quote_icon.png) Originally Posted by GenesisCoupe
La awesome followed by optibond tire gel
Steve -The Titanic Was Built By Professionals But The Ark By Amateurs- "Boanerges"
Re: Browning tire
I've had good results using TUF shine tire cleaner. Takes a few applications and some scrubbing but it works really well.
Re: Browning tire
![Quote](https://www.autogeekonline.net/forum/images/autogeek/misc/quote_icon.png) Originally Posted by frankprozzoly
The browning is called blooming and is caused by using harsh tire cleaners and some solvent based tire dressings.
These harsh cleaners and dressings are leaching out the UV and ozone blockers to the surface of the tire causing excessive browning.
This was explained by Dr. G of Optimum.
Re: Browning tire
Always use water based tire cleaners and dressings. It pays to read the label. Industrial and household cleaners are not something I'd put on my own tires let alone somebody else's.
![](https://www.autogeekonline.net/forum/image.php?u=29942&type=sigpic&dateline=1288524838&s=510653b64ed5c7b7235ea4db37f9c153)
Re: Browning tire
As far as tire protection and tire longevity goes...
I wonder if the "removal of browning" is ever a good thing to do to tires?
I'll say that the answer is: No...probably not.
But if the brown (dis)coloration presents an unlivable-bugaboo; and the tire cleaners used so far has proven to be unsuccessful at its removal:
Put some Lacquer thinner on a disposable cloth and swipe the tire with it. POOF!!! Brown will be gone...gone until the tire's rotation brings some more of the tire's built-in protection to its surface, where it will have its turn: "to turn brown".
Note:
Until the above mentioned built-in protection comes to the tire's surface...a protective product needs to be applied to the tire. What product (tire dressing) are you planning to use?
Re: Browning tire
I just bought megs trim and tire gel. I like the consistency. This is my dads new kia soul. Has 10k miles. Who knows what products were on the tires.
Re: Browning tire
Just today I was cleaning my winter tires for storage. I was using the 3D yellow degreaser for the tires. As I was cleaning the 3rd on I looked at the dry first 2 and noticed the tires were brown. I then busted out the big guns and used the Meguiar's Wheel & Tire cleaner from the detailer line. Worked like a charm!!!!!
Re: Browning tire
![Quote](https://www.autogeekonline.net/forum/images/autogeek/misc/quote_icon.png) Originally Posted by Rsurfer
Wow, I never knew this!
So I have not added any tire dressing for a few months now and have cleaned the tires the past 4 washes with two products so far:
1. Purple Power - 50/50 mix
2. Megs APC - full strength
I probably apply at least a minimum of 5 applications (plus scrubbing) per tire before the foam becomes mostly white. After the tires dry its dissapointing to still see a little brown on the sidewalls. Is spending a few hours on tires typical to get rid of this browning?? Or do I need to try something different on these new Yoko tires?
I'm trying to get them brown-free so I can apply TW Tire Coat!
Last Post: 05-27-2018, 12:19 AM
Last Post: 10-03-2017, 08:15 PM
By GreatAvalon in forum Auto Detailing 101
Last Post: 02-25-2014, 10:50 AM
By XRL in forum Ask your detailing questions!
Last Post: 04-05-2010, 06:42 PM
26 | 27 | 28 | 29 | 30 | 31 |
