Results 1 to 10 of 10
    Super Member andy2485's Avatar
    Mar 2013
    Bloomington, MN
    231
    The case for the Absorber.
    I have used one for a few years, and I have never seen a problem. I've never marred the paint, or scratched the paint. I do have a CG drying towel which i use on some cars, but the I use the Absorber the majority of the time. I don't get the hate on it!
    Super Member g35_coupe's Avatar
    Jul 2010
    413
    Re: The case for the Absorber.
    I have one but never liked how "grabby" it was when getting residual water, which could potentially mar the paint. It does soak up a lot of water but I've retired it from the car in place of some Cobra Guzzlers.
    Mobile headlight restoration in the Oklahoma City area www.okcheadlights.com www.facebook.com/OKC.Headlights
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    Quote Originally Posted by andy2485 View Post
    Most often: I don't either.
    Super Member dcjredline's Avatar
    Mar 2012
    Upstate NY
    3,340
    It would probably be pretty safe if you used it blotting instead of wiping huh?
    "Dirt likes detergent so much better than the surface that it's attached to, it'll leave that surface to go hang out with the soap"...aim4squirrels
    Aug 2013
    St Louis metro (Illinois)
    5,854
    I've used one for a very long time and not had issues with marring either. I have both a dark colored Toyota with soft paint and a black car.
    When properly pre-wetted, I've not found it to be grabby at all.
    Now that mine is so old, I have noticed it isn't absorbing water all that well and it's fraying along the edges. I'm looking to replace it with a MF drying towel only because I'm looking to use a drying aid and I don't see that working well with the Absorber Material.
    Super Member ScottB's Avatar
    Mar 2006
    South Florida
    18,803
    blow a little sand on the surface, then wipe. It is indeed grippy and has no nap to move dirt/sand up and away from the surface. Its not a bad product, but likely better choices exist.
    Scott
    Super Member AnthonyGXP's Avatar
    Nov 2014
    390
    Just like a chamois they are great "Absorbers"........but they have no ability to lift dirt or dust that may be on the surface like a MF towel would.
    If by some chance you missed a spot in the wash process you would be grinding that dirt into the paint rather than picking it up safely into the "Fibers" and carrying the particulates safely off the surface.
    Nov 2014
    390
    It's not so much that the "Absorber" would scratch on it's own, it's what could potentially be under the "Absorber" as it travels across the surface of the paint that could scratch.
    Super Member 07gtcs's Avatar
    Feb 2012
    693
    I have two and used them until I found AG. They were always quite streaky for me.
  10. #10
    Super Member swanicyouth's Avatar
    Mar 2011
    Limerick, PA
    9,388
    I've always owned at least one convertible, and back in the day I used to use the absorber. After a few uses, they always left little specks of rubber from the towel on my roof.
    Dunno.... It's too much like drying your car with a clay towel.
  1. How do you feel about Absorber?
    By slickooz in forum Auto Detailing 101
    Last Post: 03-02-2015, 09:26 PM
  2. The Absorber synthetics?
    By goodinblack in forum Auto Detailing 101
    Last Post: 04-13-2013, 01:56 PM
  3. The guzzler vs the absorber
    By Bill1234 in forum Auto Detailing 101
    Last Post: 07-04-2012, 06:33 PM
  4. absorber removes wax?
    By maddenbowler in forum Auto Detailing 101
    Last Post: 03-31-2009, 01:45 PM
  5. Absorber Verse Guzzler
    By XterraOverload in forum Auto Detailing 101
    Last Post: 11-10-2006, 10:16 AM
