Paint Correction On Harley Davidson Street Glide
Re: Paint Correction On Harley Davidson Street Glide
Well, it does look better but not perfect as you'd like it I'm sure.
If it was me I'd test a small area using your GG3 along with a 3 inch foam polishing 3k sanding disk, you can find them at a paint supply shop.
Then polish it out, see if it made any difference, if not I'd stop right there.
I've had great success using these polishing sanding disk, not very aggressive , just enough that it may remove the defects.
You could also first try the 5k disk.
Good luck!
Good luck!
I didn't do the wet sanding, the paint was already like that.
They hired me to fix the damage that was already done.
I understand that
What I'm suggesting is to NOW use a fine, 3k polishing sanding disk, not aggressive, just enough to remove the left over defects from whoever sanded the bike down.
From only looking at the pictures the compounding and polishing you used made for a big improvement.
I worked on a truck last week, pretty much the same problem, they had lines in the paint , no matter what pad combo and products I used didn't completely remove them.
The polishing disk cut just enough to remove them but not over doing it.
After I polished it out afterwards it looked great.
By slowride66 in forum Motorcycle Care
Last Post: 03-11-2018, 05:21 AM
By KMG in forum Show N' Shine
Last Post: 08-27-2014, 12:30 PM
By mpkav in forum Auto Detailing 101
Last Post: 10-17-2013, 10:37 PM
By Znig22 in forum Motorcycle Care
Last Post: 10-14-2013, 09:16 PM
By cnfowler in forum Show N' Shine
Last Post: 12-02-2010, 08:59 PM
