Help needed - how to remove stickers placed ON TOP of PPF
Right so I have a customer who has a BMW 1M with some 'Martini' inspired racing stripes that are currently on the car and he want's them removed.
The issue is that they have been place ON TOP of some VPS (paint protection film).
Typically I would approach 'sticker' removal by heating it up, pulling it off and then hitting the glue residue with either a dedicated tar and glue remover or some goo-gone, polish the area if required, and protect.
But with the VPS under the 'stickers', how is heating them up going to effect the VPS and will the goo-gone or tar remover negatively effect the VPS.
Any advice would be most appreciated.
Re: Help needed - how to remove stickers placed ON TOP of PPF
The VPS being a plastic film and uses an adhesive to stick to the paint which makes heating it risky in that you might melt the plastic and the glue into the paint or cause it to be removed entirely. I suggest you let the owner know of the risks before you attempt removing or heating.
The customer will obviously be made aware of any risks but I am really trying to find a way to get the job done without causing any damage so I am hoping someone will have some advice on how to go about.
Even if I am able to get the sticker off the PPF, how would I then deal with the remaining glue residue - I am pretty sure your typical solvent based tar and glue removers are not going to play well with the PPF?
Anyone?
i'd call the manufacturer but i believe prep solvent would be used to help remove the adhesive on the PPF...even lacquer thinner. but again, call the mfr.
Thanks guys
Just finished chatting to the manufacturer who said that heating up the stickers (he suggested using the sun?) should not pose a problem to the adhesive of the PPF.
He also recommended using mineral turpentine for any remaining glue residue...
Will discuss the potential risks with the owner and if he is happy for me to proceed, I will give it a bash
Originally Posted by lawrenceSA
Thanks guys
Thats pretty much how to tackle that one Lawrence. Do you know how long the stripes have been on there? That would be my only concern - if they have been on there for a long time they may be a little bit brittle but as long as you're patient (judging by your standards, you will be) they should come off okay. Sitting it in the sun is a good idea also but again - patience with a heat gun & not getting it too hot & you'll be fine. Definitely a mineral turpentine would be my go to - have used it safely on PPF many times. Maybe Autoglyms Tar & adhesive remover too if you have any?
Aaryn NZ.
By Wills.WindowsAndWheels in forum Auto Detailing 101
Last Post: 03-27-2017, 08:21 PM
Last Post: 09-27-2013, 12:25 PM
By garner in forum Auto Detailing 101
Last Post: 05-01-2013, 06:01 PM
By ARizzle in forum Off-Topic
Last Post: 11-04-2012, 07:07 PM
