Results 1 to 5 of 5
    Mar 2006
    Need help with Polishing
    Hey guys! I need some help with polishing. I am doing a truck at the moment, and was using the Menzerna IP with the orange pad on a PC. It seems though that I only make one pass, then the next pass it seems the product is dried or something and it is taken away. I sprayed the pad with water before I started, and am using a speed of 5. So is this normal or am I doing something wrong?
    Also, when you polish, where does the polish normally build up on the pad? I seem to have a little more buildup around the outer edge. Is this normal?
    Sorry for the dumb Questions!
    Super Member ScottB's Avatar
    Mar 2006
    South Florida
    18,803
    Is the finish warm ?? Are you polishing outside ?? Usually a polish should not flash cure for several passes. You can usually respritz your pad with water or QD in order to keep it going also. If you need a much longer polishing time, I highly suggest Optimums Polish. Remember with polishing its a small area at a time, panel by panel.
    Mar 2006
    Finish is cool. Working inside the garage so I dunno. I tried respritzing with some water and that helped a bit. I am doing just a small section at a time so I am not quite sure what the problem is. Seems as though I am not getting as much out of the polish as I should. Any other ideas? Also, is the polish buildup normal, where does yours buildup on the pad?
    Thanks killrwheels!
    Mar 2006
    South Florida
    18,803
    Never really thought about polish build up but being on the outside of the pad but does not sound wrong. I personally use three stripes going across the pad (dampened with QD) and start slow. I then ramp up to 4500-6000 depending on the polish and finish. I use a cutting pad (orange on oxidized paint), and my Vette usually only needs a white pad or grey finishing pad with polishing and then j e w e l-ing the surface. (I always follow an abrasive polish with a much lighter final polish)
    Mar 2006
    Calabasas California
    134
    Quote Originally Posted by killrwheels@autogeek
    Well said! I use a very similar method, but I use two 10" line of polish on the panel, I still use it on the pad sometimes.
  1. Replies: 98
    Last Post: 06-26-2019, 06:14 AM
  2. Replies: 10
    Last Post: 08-01-2017, 08:00 PM
  3. Replies: 8
    Last Post: 04-24-2017, 02:59 PM
  4. Paint Polishing vs Metal Polishing
    By Crispy in forum How to Articles
    Last Post: 03-13-2015, 03:43 PM
  5. Is Polishing Compound Directly Related With Polishing Pads
    By Justin in forum Auto Detailing 101
    Last Post: 07-19-2008, 07:30 AM
