Couple quick questions about collinite 845
Hey guys.
So I am planning on waxing with 845 tomorrow. I have read the comprehensive guide on here and that helps a lot.
But what I didn't see mentioned was how to do sections.
On the bottle it says to do 2x2 sections. Does this mean apply, let dry to a haze, then remove, one 2x2 section at a time?
And in general, how long does it take to dry/haze after applying?
Thanks!
Re: Couple quick questions about collinite 845
Everyone probably does it a little different, but I apply to the whole car, wait 45 minutes to an hour, then wipe off in the order I put it on. Could probably wipe off in 30 minutes in hot dry weather. 45-60 minutes in humid or cooler weather (like below 60F).
2016 Accord EXL V6 w/Navi & Sensing - Black/Ivory
2019 Acura RDX A-Spec - Black/Red; 2019 Acura TLX Base 2.4L - MSM/Black
2008 CRV EX - Black/Black 2003 Accord EX V6 - Black/Tan
I do the same. Whole car, wait, wipe off in same order. That is not 845 specific for me that is with all wax I put on.
apply thin and do the finger swipe test
Just applied two coats of 845 the other day did same as above apply to whole truck then waited 20-30minns and buffed off..
I apply via red LC pad with a PC. I feel it makes the application much thinner and easier. I tend to use 845 mostly on my boat so I go around the whole boat and then come back and buff off. If I found I applied it to thick in some areas I just spray some QD on a MF towel when I am buffing.
You guys wait longer than I do. I wonder if I'm wiping off to soon
I follow the manufacturers directions in a way that makes the process as expedient as possible.
I apply the wax to a panel.
While it's drying i apply it to the next panel or 2x2 area.
I then go back and do the swipe test on the first panel that was waxed. If it's clear I buff the wax off.
I then move to the 3rd panel or area to apply wax.
I then go back to the 2nd waxed panel and swipe test. If it is clear i buff it off then move to 4th panel. If it's not clear i leave it and move to 4th panel anyways.
I find that this method works the best. This way you are following all manufacturers recommendations and experts opinions simultaneously.
If the swipe test passes that means the wax has bonded to the paint as well as it is going to before removal. I do not see an added benefit of leaving it on longer, just makes it more difficult to remove.
The secret to getting ahead, is getting started..... ~Mark Twain
I've applied #845 to the entire car and then removed, works great every single time w/o effort or dust. I like this way because you do the application to the car all at once and then remove all at once, none of this apply, remove, apply remove, etc.
Don't forget to treat the glass and wheels too
Sent from my SPH-M930 using Tapatalk 2
2022 Elantra N Cyber Gray
I'm in the "let it sit" camp. For me, its about 30~45 minutes. I'm not very scientific on my wait times.
I'll typically apply it to the entire car then go work on something else on the car and then come back to buff it off.
By rablwo in forum Auto Detailing 101
Last Post: 08-06-2015, 07:44 PM
By 808_detail_nut in forum Auto Detailing 101
Last Post: 06-01-2015, 05:40 PM
By keepitclean in forum Show N' Shine
Last Post: 11-04-2013, 01:15 PM
By tw33k2514 in forum Product Reviews
Last Post: 01-07-2012, 01:36 PM
By shoeless89 in forum Auto Detailing 101
Last Post: 08-10-2011, 01:04 AM
