Steps required to add more Ultima Paint Guard Plus on top of Paint Guard Plus
Hi all,
A few weeks ago I applied some Paint Guard Plus after washing, claying, and Paint Cleansing.
If I want to add some more in the future, do I have to repeat the same steps and if not what would I need to do to do it correctly?
I wonder about polishing too much; I previously used a white pad but am thinking of next time using a grey pad. The paint is in excellent condition.
Thanks for any suggestions or advice.
Ed
Re: Steps required to add more Ultima Paint Guard Plus on top of Paint Guard Plus
No need to polish again unless you are trying to correct defects. Just wash and and a layer of UPGP.
Sent from my HTC One using AG Online
Originally Posted by
conquistador
Thanks. For some reason I thought I had to repeat the cleansing step by using something like Pinnacle Paint Cleanser or Ultima's version before applying the sealant. I assume after the wash do a baggie test before applying the Paint Guard?
Thanks,
Ed
eyost
Thanks,
Ed
I wouldn't do a Baggie test unless the car has been outside in the elements like parked under a tree.
KillaCam
I avoid trees due to the bird bombers, but it is a daily driver that is garaged at home. I was meaning baggie test and if it isn't slick then clay before applying more Paint Guard. If I clay, would I have to polish?
Thanks again,
Ed
eyost
Thanks again,
Ed
Not if you use a very fine clay and lots of lube. You be the judge! I prefer not to polish very often. No sense in removing paint all the time.
KillaCam
Thanks. I use DA clay and their lubricant. Looks like ya'll are saving me a lot of work. I hope I haven't done too much to the car; have applied Pinnacle paint cleanser three times with a white pad on DA polisher. The car was brand new when I started.
Have I done bad?! I was told to clean every time using Pinnacle prior to applying sealant. Does it vary dependent upon the type of sealant. I was also using Wolfgang Deep Gloss Sealant.
Thanks,
Ed
eyost
Thanks,
Ed
Normally only horizontal panels need claying a lot sooner than the vertical panels. You could clay and then just put a few coats of UPGP and that will give you protection for a long time.
I haven't used pinnacle paint cleanser but I don't think it's abrasive so you can use it as often as you want, but it will remove the protection that's already on the paint.
