Megs apc
Reading the difference between apc and apc plus just seems to be the Orange scent. I would've bought the orange scented one if I knew about it. What is your preference. So far I've just used the green apc on my tires and it sure does work. Gets the tires squeeky clean
The tires come out so nice you almost don't need a dressing
Speaking of tires. I used a cheap Costco MF to wipe down. It gets black obviously so it goes in the garbage. I can't continue using a towel every wipe. That'd be alot of towels. Do you guys just air dry tires.
I uses meguiars d101 the green one even consider trying tuff shine tire cleaner also instead of buying yellow towels buy a few black microfiber towels they reusable, and hides the staining
Re: Megs apc
I let mine air dry, no issues. If I don't have the time to air dry them before putting tire shine on, I'll just use some paper towels to dry them.
17 Land Rover Discovery: Fuji White; 07 Land Rover LR3 SEV8 4WD: Java Black Micatallic; 18 Jeep Wrangler JLU Sahara: Black; 05 Jeep Liberty Limited 4WD: Light Khaki Metallic
Re: Megs apc
APC+ also had less foaming action. Other than that they are both good.
Re: Megs apc
I believe Meguiar's APC+ has been discontinued
Yes it has been especially in the gallon bottles.
Re: Megs apc
apc+ is less foaming and for use in extractors. I use it a lot. I believe you have to buy a 5 gal pale to get it now and the price went up. I don't know if AG sells it that way or not. I stocked up when they were getting low. I have not tried the green stuff but it may even work better because it foams. I needed the low foam for my myttee.
As far as the cheap Costco towels go, put you about 5 in a bag, and only use them for the tires. Once they get really bad, wash them with degreaser. They're just tire towels after all.
See, this is why I ask you guys for advice. I don't want to put those nasty towels in the washer. Never even considered just washing them in a bucket
Re: Megs apc
do a tire scrub with a brush, you'll get most of the black. then don't worry about getting towels black from tires, after they are scrubbed good, you can use a tire sealant, not a dressing. and you won't have the issue of gunk on tires anymore. that tw tire coating is holding up real well for the job.
By rouxster in forum Auto Detailing 101
Last Post: 03-17-2014, 10:35 PM
By Rockeey in forum Ask your detailing questions!
Last Post: 12-18-2012, 10:34 PM
Last Post: 02-08-2012, 03:24 PM
Last Post: 10-24-2011, 09:09 PM
By ScottB in forum Product Reviews
Last Post: 02-05-2011, 10:56 AM
