Re: is M105 & 205 really the Right Products?
Originally Posted by A.P.A.D.
The Megs combo is great and gets the job done. I encourage folks to try M100 instead of M105. M100 dusts less, finishes nicer, and is actually cheaper.
I am actually going that route too actually.
Originally Posted by jaymz
M101 is a lot easier to use than #105, and finishes out better, too.
Jim
THIS!! I just used M101 for a complete correction on a swirled out Black E60- WAY less dust and awesome correction.
Originally Posted by cartract
Awesome! Are using a rotary or a DA for the 4500. Thanks
I do not have a rotary. Just a Flex 3401 and a Rupes LHR 75E Mini.
Originally Posted by MagRed Mike
well, it seems the menzerna 4500 is a sample i'd like to see results with on mine. will it work well with a DA?
Megs 105/205 are great products. That being said, I am now a Menzerna guy. I use the FG400 in place of the Meg 105 and SF4500 for the 205. IMO Menzerna is a better correction product. The SF4500 will work well with your DA. I gave away my Megs because of Menzerna. Again, that is me...someone could disagree.
The combo of Menzerna is something to consider if you are looking for another product.
105 works very well, but can be maddening in terms of working time. 101 is a step upon work time, but pretty expensive. I haven't used Menz FG400 yet, but it's on its way.
Thanks....I use a Flex 3401 as well...what speed setting do you use with the 4500? Thanks again.
Thanks....I'll be trying this out shortly.
105/205 are king.
every other product has been chasing them since they came out.
If it works why fix it?
I see hundreds of detailers buying every product under the sun then selling it after they only use it once. Makes no sense to me at all.
I have a few different compounds and polishes in my rig but I always grab 105/2 first and it works 99% of the time.
With a PC FG400 will make your life so much easier. The good thing about it is that it is SMAT/DAT hybrid. So it will diminish as well as cut until you stop. I have done several cars with it and was down to near LSP ready on white foam with FG400. No haze what so ever. No need for a second step.
You can also try HD Adapt. It's cheap and get great reviews. Same idea they call it something different and it also has a chemical cleaner in it as well.
I don't keep a lot of compounds on hand. FG400, 4500 and I'm gonna give HD adapt a shot. I have a lot of samples I noodle around with. I sampled 105/205 before and the dusting killed it for me. I'm all about less is more but it needs to be fast. I don't want to have to follow up with another step unless I have to. So if I can use FG400 and white pads and get near LSP ready I'm good.
inDetail, "It's all in the details."
By Ncs0816 in forum Auto Detailing 101
Last Post: 01-17-2014, 01:15 AM
By BrianMcLeod in forum Auto Detailing 101
Last Post: 08-19-2013, 12:30 AM
By flaco in forum Ask your detailing questions!
Last Post: 08-17-2010, 01:44 PM
By Mike Phillips in forum New Car Care Products
Last Post: 04-05-2010, 12:08 PM
By O.C.Detailing in forum Ask your detailing questions!
Last Post: 10-07-2009, 10:44 AM
