Still a musky smell from air vents
Hello All,
I've been doing cigarette smoke removals with zero issues in the past and received at least 80% improvement from each detail.. However;
I have a car I just can't get the musky smell to go away, and it ONLY occurs when the air is first turned on. After about 5 seconds of blowing a somewhat of a foul odor, everything is just fine. I steamed, I changed cabin air filter, and used Dakota Bomb as well as the new Meguiar's Air Re-freshener ( break in tab and run the air on high, recirculate for 15mins).
Any other suggestions?
Again, it is only after you start the AC system and lasts only 5 seconds.
Thanks!
Owner at Clean N' Shiny Auto Detailing Inc.
If it was my car I would remove the air filter. Use a vacuum cleaner to clean it and spray it with a Dakota air bomb.
Re fit and them switch on air con to recycle and spay a decent amount of air bomb in the car
Close the doors and windows and let it run for 5 mins and hopefully that should work.
If not, I am not sure
Re: Still a musky smell from air vents
You need this: 1Z Einszett Klima-Cleaner Air Conditioner Treatment
You can also go to an HVAC supply store and get a can of evaporator cleaner. Just make sure it's a no-rinse type.
PS That's probably a musty smell, if it's musky you've got a different problem!
Musty!!** thanks for the correction.
I will look into the products mentioned above.
I had only temporary luck with Dakota Bomb on this car. Every other car worked well.
Thanks All!
I would turn on the A/C and spray Lysol into the inlet vent in the windshield wiper cowling.
Thanks All!
Are you running the A/C when you Bomb?
Sorry, just saw in OP that you are
That south American river place has Nu-Calgon Evap Foam No Rinse which seems to be a similar product, but it doesn't come with the tube to snake down the vent like the 1Z. I can vouch for the 1Z, it works great for this kind of thing.
try RID ODOR PRO just did 08 ford exp. with same problem came out fine after 2 months
Did I miss something? But have you checked for a "cabin air filter?"
Bill
Yeah, you missed it in the first post:
Last Post: 07-18-2022, 11:18 AM
Last Post: 08-14-2019, 12:07 AM
By dwaynesworld in forum Auto Detailing 101
Last Post: 04-26-2013, 07:31 PM
By nickgodfrey in forum Auto Detailing 101
Last Post: 02-09-2012, 08:42 PM
By bladerunner in forum Auto Detailing 101
Last Post: 10-04-2007, 10:53 PM
