Results 1 to 8 of 8
    Super Member Dr_Pain's Avatar
    Nov 2012
    South Central, Louisiana
    2,196
    Rupes backing plate velcro failure?!?
    This is my Rupes 5" backing plate which developed a bad case of "velcro-itis". Has this ever happened to any of you guys?
    Was in the process of polishing using a Meg MF cutting disc and all of a sudden felt a wobble. I've had a few MF velcro failure but this was different. On inspection I noticed that the backing plate velcro was the problem, not the velcro off the MF disc.
    This 5" backing plate has seen some intense sessions and never failed so what gives?
    https://www.facebook.com/FlawlessFinishDetailing
    Dr. Claude Tremblay, Co-owner/Senior Detailer, Certified CQuartz FINEST Installer
    Super Member Rsurfer's Avatar
    Jan 2007
    14,095
    Re: Rupes backing plate velcro failure?!?
    Intense usage equals wear, equals replacement. Some will just grab the pad and start ripping it off. With the Rupes system, you must hold the backing plate at the edge of the velcro as well as the pad and slowly peel at an angle.
    Edit: It also appears that the edge has been bumped a few times.
    Nov 2012
    2,196
    I agree with everything you are saying and just need to point out that I do not just simply rip the pad off since taking a pad off the Rupes velcro is like trying to peel 2 teenagers off of one another. It did not fail while removing the pad, it failed during use.
    Yes I have made the "faux pas" of hitting the pad/backing plate a couple of times, as I was getting used to the throw, but that has little to no bearing on the velcro adhesion/failure does it? I've had way more polishing with the 6" and it has yet to fail (so my bumping or pad removal technique can't account for 100% of the issue seen)
    Super Member Wes Bremec's Avatar
    Jan 2012
    473
    I notice when in use my mf cutting disks on the Bigfoot that the heat produced is pretty radical. The heat potentially loosened up the bonding agent between the backing plate and the Velcro.
    Nov 2012
    2,196
    Quote Originally Posted by Wes Bremec View Post
    Sounds very plausible Wes! I wonder if this is salvageable or just spend another $40 to get a replacement?!?!
    McKee's 37 Product Support
    Jan 2011
    7,265
    That could play a role, but it's also possible that the backing plate is simply warn out. Backing plates don't last forever.
    Quote Originally Posted by Dr_Pain View Post
    I would play it safe and get a new one.
    Nov 2012
    2,196
    Quote Originally Posted by Nick@Autogeek View Post
    Thanks for the reply Nick! It was just weird how it failed
    In time out
    Nov 2012
    South of Atlanta
    3,937
    Whew!
    While I agree that backing plates don't last forever, the Rupes "system" tends to/seems to lend itself to an inordinate amount of (self induced) problems. I've not had a backing plate failure just yet, but I did have a brand new microfiber cutting pad come apart recently using it for only the second section on a hood. (It was stupidly hard paint FWIW, but still.... never had the Meguiar's pads do that.) Building in the crazy grippy Velcro, then gluing that to foam (on both a backing plate as well as.... say the microfiber pads) that naturally gets warm (to say the least) seems like an invitation to trouble.
  1. G21 Backing Plate Failure
    By Mantis in forum Griot’s Garage Polishers - BOSS - 6" DA - 3" DA
    Last Post: 07-16-2020, 11:31 PM
  2. What type glue for backing plate velcro?
    By KirkH in forum Auto Detailing 101
    Last Post: 09-25-2018, 08:45 AM
  3. FLEX 7-12 80 velcro backing plate
    By jmbaker3 in forum Flex Polishers
    Last Post: 07-08-2018, 05:08 AM
  4. Velcro Melted On Backing Plate
    By tommythecat in forum Auto Detailing Tools and Accessories
    Last Post: 05-12-2013, 09:52 PM
  5. Flex 3401 backing plate velcro
    By tuscarora dave in forum Flex Polishers
    Last Post: 10-01-2010, 10:25 PM
