Dp Wheel Glaze.. No Exactly Why Is It A Good Thing?
In one of the recent threads DP Wheel Glaze was promoted as sooo much better than "Wheel Wax"...because "Wheel Wax" does not last very long. Ok so I buy some..
Now here is the thing.. you are supposed to use it WEEKLY.. Wow it is a "moussy" kind of substance that you apply like a wax or polish. Then you have to buff it off.. NOW exactly what is easy about that? It is like work ! Especialy trying to get it completely off the insides of the wheels. Then it needs to be repeated EVERY WEEK. Ok, so why is that a good thing?
I mean it does work well enough but the mainatance is substantial.
2013 Infinity JX35 White Pearl, 2009 BMW 528XI White
1969 Primrose Yellow 4.2 XKE
2002 Ford F-350 Powerstroke 7.3
I clean my wheels which are aluminum with klassse AIO,then top with wolgangs paint sealant.Lasts a good while and NO heat does not melt it.Both products easy on easy off.
You can do it,we can help!
DP and PB's are good wheel sealant products, but IMO you can just use AIO and spray of AW and be set, this is my combo on my chrome wheels and works perfectly, quickly and easily. Beads water off easily 4 weeks for me. I usually redo once a month.
Because of the extreme heat the wheels see, partly because they are so close to breaking system, it is advised to reapply weekly. Also because most use harsh wheel cleaners that can remove it. I have found that using DP once monthly is perfect as long as you use soap/water only for remander of the month. You then use wheel cleaner, polish, and reapply just like your finish.
DP is a little harder to remove as has some slight cleaners. Poorboys buffs easier as doesnt have any. This is for those considering which is easier to remove. If you have a stubborn spot, try a little qd'er on a towel.
Thanks.. Once a month I can live with. The product does work well !
does a wheel sealant really that better over a good wax/sealant?
I used to use the klasse twins on my wheels but now I use JS109 and love it. I may be wrong but does any good wax (ie: collinite) or sealant (Klasse, JS109) will do the same thing?
a carnauba wax could not live with those extreme heat shifts ... most sealants would probably keep up. I really dont know if there is an active ingredient in just wheel sealants to deal with heat over normal sealant.
I'm with Surfer...Bought the DP Wheel Glaze but found spritzing with Aquawax does the same thing without the hassle of buffing out the wheels. In addition, the wheels still bead up after using AW and lasts just as long as Wheel Glaze.
Wheel Glaze is the only product I've bought here so far that I'm relatively disappointed in because of its application. If you're going to reapply weekly, AW is the choice for me.
Just my 2 cents.
Never lie if your memory stinks...
For those using AW, does it give the rims a shine? I notice DP gives a great shine on every rim I use it on.
Excellent shine with AW. Personally I can't tell the difference between the shine of DP and AW.
By vanev in forum Off-Topic
Last Post: 01-14-2016, 01:00 PM
By Setec Astronomy in forum Off-Topic
Last Post: 01-07-2015, 01:58 PM
By Crazy Amos in forum Auto Detailing 101
Last Post: 01-25-2011, 08:52 PM
By Kelso in forum Auto Detailing 101
Last Post: 12-14-2006, 03:42 PM
