Discolored dashboard from sun or ??? any way to bring it back?
I have a 1986 Mustang SVO that sat out in the sun for a year, and now I am trying to get things looking back right on it. The dashboard is very discolored either from the year in the sun or Armor All which was very popular when the car was new. Is there anything anyone would recommend to try to clean it? Or if that doesn't work what would be my next step (short of trying to locate a new dash)?
Re: Discolored dashboard from sun or ??? any way to bring it back?
I think the dash is probably discolored not from ArmorAll or sitting in the sun for a year....but from sitting in the sun for 28 years. Doubtful you are going to bring it back to looking new.
You are going to want to gently clean it and then "moisturize" it with some dressing.
I'd probably use these:
DP Total Interior Cleaner cleans plastic, vinyl, leather, carpet, and upholstery without harsh solvents or caustic chemicals.
303 Aerospace Protectant, 303 aerospace, 303 protectant, aerospace protectant, 303 products, 303
Well it could be discolored from the sun, armor all or moisture therefore I would clean that dashboard with apc(all purpose cleaner) to break though all the layers of dressing etc then I would take a water based dressing of choice and apply three coats of dressing with 15 minute dry time in between each coat now hopefully the dash is looking even again now you can apply one more coat and knock the shine down with a semi damp towel if you don't like a shiny dash. good luck my friend
On a car that age you can try what's been advised but really it's probably just faded from age. If the suggestions don't work you can always try a vinyl and plastic dyeing paint.
If none of the suggested fixes work: and it is really bothering you:
I think you should be able to find a replacement online for around $200
Thanks for the suggestions. I will have to order the DP interior cleaner, since I doubt it is available locally.
No, it has sat in a garage for most of its life. Only driven for fun or raced now and then. It only has 32,000 miles on it and I am the original owner.
Is it difficult to paint/dye vinyl? That may be my only option if cleaning it doesn't work out.
Sadly there were less than 10,000 SVOs made, so parts are hard to source. So I am hoping I can get the dash looking good again with the great suggestions I have gotten.
Being that the dash has only incurred discoloration:
ArmorAll can't be the culprit. Instead...
Isn't:
"Dash cracking" the often reported phenomenon that allegedly happens from its use? ![Big Grin](https://www.autogeekonline.net/forum/images/smilies/Dgrin.gif)
Anyway...As suggested:
A good, yet gentle, cleaning; followed by an application of 303AP: should bring new life to the dash.
Note:
Don't be surprised/worried if more than one 303AP
application is needed for this rejuvenation to occur.
![Quote](https://www.autogeekonline.net/forum/images/autogeek/misc/quote_icon.png) Originally Posted by gbrittenum
I have painted a few leather and vinyls parts so far and did not find it more difficult than painting anything else. The tricks is to apply many very light coats instead of 1 or 2 heavy ones. Depending on the brand of dye paint you purchase, it's usually 10 minutes in between coats. So you are talking about a 2 hour job if you go for 5 or 6 coats.
Once the paint has been applied, I would wait a few weeks and apply a leather conditionner on it. Then make sure to apply protective products to make sure it does't fade again.
Also if painting or dyeing make sure its super super clean. You have to remove all protective products in all the cracks and crevices. Scuff it with a light sand paper and do a good scrub with a mineral spirit or a paint prep surface cleaner. You may want to even scrub it in with a brush. If you don't it will bubble up and never stick.
By Bamafire in forum Auto Detailing 101
Last Post: 12-12-2012, 12:52 PM
By sixgun95 in forum Auto Detailing 101
Last Post: 09-26-2012, 09:27 AM
By Finkikus in forum Auto Detailing 101
Last Post: 01-26-2012, 03:29 PM
By turboman808 in forum Auto Detailing 101
Last Post: 12-15-2008, 07:15 AM
By Tonya in forum Auto Detailing 101
Last Post: 08-28-2007, 08:01 PM
26 | 27 | 28 | 29 | 30 | 31 |
