I watched a video of how to remove emblems. Does anyone have a 13 accord? I just want to make sure that the accord and sport emblems are glued and there are no holes
They is only adhesive on them. Just did a co worker's 2014 accord sprit coupe and no holes. Use a blow dryer and fishing line. If you don't have fishing line, use tooth floss. Lightly heat up emblem, then use your line or floss and work it behind the emblem as if you're trying to saw something and it will come off. Some need more heat than others, but once you start you adjust your procedure.
Using fishing line place it behind the emblem and start sawing. Once the logo is off use goof off to remove the remaining adhesive. I don't have a heat gun so I used a torch with no problems.
