Compound ?s for hard clear
Ok I have a 2007 corvette and I hear it has hard clear.
I have used HF polisher with 5.5" pads
Ive used mf cutting pads by Meg and CG
As well as foam cutting pads
The compounds and polish I have tried is all CG v line v34/36/38
I have tried all the tips about small work areas, .slow arm speed, clean pads, the results look better but I dont seem to be getting enough cut/correction
Do I need a more aggressive setup??
Should I look into the surbuf pads? Or look into a better compound/polish like menzerna?
Sent from my SAMSUNG-SGH-I747 using AG Online
Re: Compound ?s for hard clear
I would give m105 a try or menzerna fg400. I prefer menz fg400, but you can get m105 at your local auto parts store.
Rupes Bigfoot 21
Rupes Mini
PC 7424XP
If it looks better hit it again with M105 and then again if need be. I personally like to see improvement and use it as a gauge to stay "the least aggressive" as possible. Far too often we are tempted to reach for something that gets it all and NOW which may be more aggressive than you need to level the paint to just the right point. Maybe a wool pad if you haven't tried that.
If your results were minimal i would consider stepping it up but if it's say 50-60% better, i like to stick with it and get the remaining with the same approach.
(whoops...i misunderstood that you were already using M105. That's my go to product and vary the pad choice at times).
Reason: Clarification
It looks better in the area that I spent an hour on (1/3 of hatch) not much area at all. I originally polished with a light polish and use blacklight and it looked good but I think I just filled in everything as it soon started looking like before the blacklight
Should I try
FG 400
Or the
SI 1500? (1 review even said this was perfect on his corvette hard clear)
I've read tons of great stuff on Menzerna. I wish I hadn't bought all 3 of the CG polishes :-(. They did work good on a honda recently though
Originally Posted by Daviddear30
Should I try
FG 400
Or the
Always try to do the "Test Spot"...along with keeping
the "least aggressive first" processes in mind.
Ha,
that chart caused the confusion to start with.
I would have to buy one as I don't have any. Can't buy several more just to try. :-( so I was looking for opinions on them. I see that fg400 is pretty aggressive and the corvette is my personal car so I want to get something to get it back to newish paint condition. I bought it used and has plenty of defects
I use both with great results on all corvettes I do to include my own 2008. White polishing pad for most sometimes orange pad. Only once have I usef the yellow componding pad but with great results. I always followed with sf4500 to top it off.
Sent from my SAMSUNG-SGH-I317 using AG Online
By bmwstephen in forum Auto Detailing 101
Last Post: 06-07-2015, 06:51 AM
By Don M in forum Ask your detailing questions!
Last Post: 05-07-2015, 10:54 AM
Last Post: 11-10-2011, 11:19 AM
By BimmerFerret in forum Auto Detailing 101
Last Post: 04-24-2010, 07:53 AM
By Whitethunder46 in forum Auto Detailing 101
Last Post: 01-07-2007, 11:40 AM
