M205 Issues
Hello everyone I recently purchased m205 and Griots 6"inch polisher for my first paint correction. The vehicle is a 2012 white Honda accord. I was using m205 to remove some light scuffs on the paint with a orange CCCS 4" pad followed by a 4" white CCCSpad. I know i need to work on my technique but now I have scratches on paint that were not there before. I primed my pads then applied 3 pea size drops on pads spread the product out first then I tried the Griots on Speed 4.5 for about 4-5 passes with orange and same with white pad. One of the areas i am working on is convex panel on passenger side and I am having difficulty keeping the pad flat. Should i consider doing this area by hand with m205 on a orange or white pad?, or is this a sign that m205 is to aggressive for my paint?.
Any help would be appreciated?
Re: M205 Issues
I'd want to try the white pad with M205 and if you still get marring do you have a black pad? How much pressure are you exerting on the machine and pad? Lighten it up if your squishing the pad and see what you get with a white pad. Maybe even the white pad you're using with M205 is creating some issues with what sounds like soft paint. I do like M205 but do you have any other finish polishes?
Re: M205 Issues
Honda's can sometimes have soft paint. Try using a finishing pad with M205 and see if that works.
Re: M205 Issues
yes i do have black pads just picked some up. As for pressure I am using moderate pressure but i notice if the pad stops spinning and it has a few times especially when i am going over the curved edge of the panel. as for other finishing polishes I do not have any. reading forums and other online users recommend ultimate compound. i was considering Menzerna 4000 or 4500. Any recommendations?.
thanks for your help.
Re: M205 Issues
Thanks for the response will try a finishing pad.
Re: M205 Issues
I would highly recommend the Menz 4500 and with a black pad on your soft paint may look miraculous. Also make sure your towel materials are surgically clean too.
Given what you have though i might be tempted to try the M205, black finishing pad and light pressure and wipe clean with your sugically clean MF towel.
Re: M205 Issues
Thanks for your help once again will give it a shot and upload pictures.
Re: M205 Issues
You said there are scratches that were not there previous to your polishing.
Are you sure they are not RIDS that are showing clearly due to the fact that they were hidden amongst swirls and other defects that you've now removed?
Possibility they are rids. I going to try a finishing pilish. Thanx for the reply.
Sent from my SGH-I727R using AG Online
Re: M205 Issues
I just ordered 4000 since I have 4500 and was wondering the difference or when to use each one. I think u answered my question. Thanks
By Fallguy007 in forum Auto Detailing 101
Last Post: 08-17-2019, 12:15 AM
By Redfireshaker06 in forum Products Guides
Last Post: 08-31-2016, 01:44 PM
By rouxster in forum Auto Detailing 101
Last Post: 03-21-2014, 11:52 PM
By DaveT435 in forum Auto Detailing 101
Last Post: 07-07-2012, 11:42 AM
By ChineseGuy in forum Auto Detailing 101
Last Post: 02-26-2011, 01:33 AM
