Results 1 to 6 of 6
    Junior Member Imacanyone's Avatar
    Feb 2014
    Palm Bay, Fla
    86
    Reverse osmosis water
    This might be a dumb question but I will ask anyway. When mixing/diluting my different detailing products can I use reverse osmosis water instead of distilled water? Is one better than the other?
    Thanks as always
    "The vision must be followed by the venture. It is not enough to stare up the steps - we must step up the stairs."
    Jan 2013
    Re: Reverse osmosis water
    I would stick with distilled. Reverse osmosis (RO) forces the water through a semi-permeable membrane to remove impurities. The membrane pore size determines the size of impurities that are removed. However, there are further steps that should be used to get truly good water, like a carbon filter to trap organic compounds and ultra-violet light to kill microbes. So, if you don't know all the steps taken, the water may still have stuff in it you don't want, like chlorine.
    In time out
    Nov 2012
    South of Atlanta
    3,937
    Well I don't know about microbes and such. But most any decent RO system will have a carbon stage as well. I've been into aquariums for a good 20 years, planted tanks and such, and RO water is much preferred for fish tanks, where THERE you cannot have any chlorine at all. (Unless you have goldfish.... they'll darned near live in the toilet!)
    I'd suspect that OTC gallons of RO water will have been processed with everything that normal filtered water would be, plus of course passed through the RO membranes.
    Super Member JHL88's Avatar
    Mar 2013
    1,137
    I believe De-Ionized H20 is more pure than RO water. That's what I use.
    In time out
    Mar 2013
    Los Angeles, CA
    4,845
    Are you guys also using RO or DI water in your wash buckets?
    If not...I don't see it as an issue overall.
    IMO the main thing you should concerned about when diluting chemicals is minerals in the water that could be left behind.
    Super Member poweraid's Avatar
    Mar 2011
    wausau, wisconsin
    1,046
    I use mostly ro water except for bottle fills . even though I have a cr spotless , my ro dries spot free . my ro comes from and no it's not my personal water filter system , I have to truck this water in .
    compliments of employment
  1. The Reverse Test Spot
    Last Post: 01-21-2019, 09:14 AM
  2. Would Reverse Osmosis water be ok to wash a car with?
    By W8TLS in forum Auto Detailing 101
    Last Post: 01-12-2017, 09:17 PM
  3. reverse osmosis filters?
    By VW Drew in forum Auto Detailing 101
    Last Post: 11-01-2015, 10:59 AM
  4. reverse osmosis h20
    By poweraid in forum Auto Detailing 101
    Last Post: 04-30-2011, 12:01 AM
  5. Replies: 19
    Last Post: 04-06-2011, 10:15 PM
» June 2024
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
