M205 alternative?
Typically I'll use M105 then follow it up with M205 but unfortunately I'm out. I want to use up my older products before buying anything else. Can I use Poorboys SSR1 or Zaino AIO instead of M205?
Re: M205 alternative?
I'm pretty sure you can.
Doing a fast search here, I'm convinced SSR1 will do the job, however I was not very convinced by Zaino product since I don't know it better.
In my thoughts, it can be too mild depending on severity of defects you may inflict compounding with M105.
If you achieve almost perfect finish with M105, then Zaino AIO will do the job.
You can always try to work it on different pads (a polishing pad or a finishing pad) to see how far you can go with it.
To re-stock your finishing polish, I'd recommend taking a look at Menzerna SF4000. If you'd like, when you place an order at AG, get a sample of Pinnacle Advanced Finishing Polish.
It's almost (if not) the same product, I believe it's tweaked for AG specifications, but they work the same and will give you a great idea of how SF4000 would work out.
Hope that helps a bit, although I never used neither Zaino or SSR1 your talking about.
Kind Regards.
― Isaac Newton
I find Menzerna PF2500 comparable to M205.
I like the Menzerna Products. For final polish I go with SF 4500 for polishing. Menzerna is great stuff
HD POLISH
Are you sure?
Wow, this comment almost made me fall off my chair...
Look what I've found!
(maybe the worst picture I've ever made, but I've took a picture with my computer cam in a hurry just because I can't believe this...)
The picture on your left I took from AG PF2500 product page, the label states PF2500 is a high performance Polish, and the 'aggressiveness scale' on bellow part of bottle points it at ~the middle.
My PF2500 (at your right) says it's a High Performance COMPOUND, and if you look at the scale, it's pretty much on the Coarser side.
It works here as a compound, it's much more aggressive than M205.
However, maybe I was missing something. I wish my PF2500 was a polish (instead a compound), I've talked about it today how I like FG400 finish much more than PF2500... That may be because mine is a harsh compound while yours is a high performance polish.
Mine is from Germany, not Menzerna USA...
Thanks for pointing that out.
Kind Regards.
― Isaac Newton
Originally Posted by FivePoint.0
HD POLISH
+1 Finish is excellent and wipe off is a breeze, but don't use too much -- only requires 4-5 pea sized drops to prime (don't rub it into the pad) and 2-3 small drops after the initial section.
Another vote for HD polish.
And one more for HD Polish.
I have used plenty of Zaino AIO. Trying to use up what I have left is taking quite a bit of time. I don't feel it has much cutting ability at all. More of a chemical cleaner. Supposedly it has a little abrasive, but I doubt it's much. I add a little ZPC to the pad when looking for a little more cut.
I use 105 and 205 when I am looking to due some serious polishing.
However, I think I will be trying some Wolfgang polishes next time around.
By bluegrass in forum Auto Detailing 101
Last Post: 12-29-2020, 09:29 PM
By Fallguy007 in forum Auto Detailing 101
Last Post: 08-17-2019, 12:15 AM
By ramki1459 in forum Auto Detailing 101
Last Post: 08-17-2015, 08:47 AM
By Largebore in forum Auto Detailing 101
Last Post: 07-23-2012, 06:24 AM
By apotelyt in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 07-01-2006, 04:42 PM
