Proper engine detailing techniques
How do most of you detail under the hood? What products have you tried?
i have tried several products but found none that does what it says. simple green so far has been my favorite. i try to cover what looks to be electrical and open air intakes,using a low pressure (household faucet) with a fire dept. type nozzle for the different spray patterns,and a long reach soft brush. still looking for better products all the time which is the reason i joined this web-site!
I like to use DP Exterior Surface Cleaner in one of our foam guns. I cover the electronics (alternator, battery, MSD ignition, etc) with plastic bags, rinse everything, soak all areas with the Gilmour foam gun....then I let it sit for a bit and settle in. After that, I hose everything down and rinse it real good. I then start the engine, let it idle for a bit, dry out the excess water and dress all plastic/rubber.
Originally Posted by dennish
Beautiful!
Originally Posted by Matt
Beautiful!
It gets driven about 3000 to 4000 miles a year and even to work seveal times a month.
Wow...now THAT is cool.
You should post up more pics of the car in the Show N' Shine forum!
Ow my, very nice!
APC diluted 3:1, soak, scrub, rinse. repeat if necessary. I havent found dirt or grime that has stood up to that. Nevr_Dull on the metal, and 303 on the plastic/rubber.
By pittpens24 in forum Auto Detailing 101
Last Post: 08-27-2019, 12:20 PM
Last Post: 12-31-2016, 11:30 AM
By Ivan Rajic in forum Auto Detailing 101
Last Post: 05-10-2013, 12:11 AM
By stevenKidman in forum Tricks, Tips and Techniques
Last Post: 02-21-2013, 08:44 AM
By ScottB in forum Auto Detailing 101
Last Post: 08-14-2008, 02:16 PM
