Foam Washing Technique Question
Hi All..
Just used my new foamblaster.....
All I can say is WOW!!
With 2 oz of soap and then water ..the foam was plentiful
My question...
After foaming up the car...I waited 5 minutes for the "dwell" to work in
Then I started to wipe cafefully away the dirt using the "rolling" technique with the one bucket clean water with grit guard..
my problem is by time i got to the other end of my car ....It dried up.
Yes, I was in the on and off sunlight ...but I dont have shade to work with.
I've also seen people wet down then foam and people apply without wetting down.
There was also a video where that Chemical Guy sprays the gun onto his mitt and wipes down.
I also saw a guy the washed and foamed his car 4 times!!!
Please give me your best technique on approaching this without product drying out.
and being economical and fast.
Thxs
Mike
This is exactly why I haven't bought a foam canon. My suggestion would be to find an ez-up on craiglist for $40.
Sent from my HTC6435LVW using AG Online
Re: Foam Washing Technique Question
Can you break it up into sections? That is, foam a section, let it dwell then hit it with your wash media? Move from section to section.
looks like the path I have to take...thxs
Here is what you do:
Foam
Let it dwell for 5
Rinse
Foam roof
Use mitt on roof
Move onto next panel do the same..
Usually I'll rinse half way through the car. Then dry obviously.
I'll normally foam as a pretreatment, then rinse, then 2BM. Trying to pretreat with foam then foam again as part of a wash step just isn't efficient for me - takes as much time as a 2BM and uses more soap.
Some people spray the for right on front of the wash mitt as they are washing - just slightly different than doing it one panel at a time.
If it's a foam gun maybe but if you use a cannon in one hand and a mitt in the other gl to you.
By Mike@DedicatedPerfection in forum Auto Detailing 101
Last Post: 08-10-2015, 04:09 AM
By sberk1012 in forum Auto Detailing 101
Last Post: 09-24-2014, 10:39 AM
By NLS8520 in forum Auto Detailing 101
Last Post: 04-16-2013, 06:29 AM
By muyo in forum Show N' Shine
Last Post: 08-03-2011, 11:06 AM
Last Post: 05-08-2011, 12:11 AM
