Tuf Shine: Hurry Up, Mother Nature!
I bought the Tuf Shine Kit a couple of months ago, but I haven't been able to use it because, well, winter has been in the way. Today it is supposed to be 60º, so I pulled off one of the wheels off my 2009 Honda Element and cleaned the reverse side as best as I could. Sadly, the corrosion that is towards the hub will still be visible when the wheel is mounted. There is baked-on crud behind the spokes that just won't come off too, not even after working on it a looong time. But at least that is not visible.
I bought the E used back in November; it had 40K on it. The dealer I purchased it from installed two new tires in front, and I have been using Pinnacle Black Onyx on them. The one I am working on wasn't too dirty, because I didn't have to scrub a lot with the kit's provided tire cleaner. Now I am just waiting for the temperature to rise about 50º. It's 1:40 PM now, and the temp is 48º. Hurry up, Mother Nature!
Some pics of the proceedings:
A lot of trouble just to clean one wheel. The space where the spare is stored is dirty too; gonna have to clean that out another day. Should I put Tuf Shine on my spare? Hmm.
Can you spot where the bird pooped on my car? While I was working on the wheel, a bird pooped on my head.
Yuck.
Just waiting for the temperature to rise now.
Re: Tuf Shine: Hurry Up, Mother Nature!
Much to my wifes chagrin, Ive washed wheels/tires in one of our bathtubs, then applied coating(s) to them in our basement.
Mother nature be damned!
Ordered some myself. I have been cleaning the tires like crazy. When the kit gets here hopefully won't need too much more.
I decided since I had one wheel off, I may as well do the others. I am now on wheel number three. LOL. This would be so much easier if I had a lift and could remove all the wheels at once.
I could swear I cleaned the first tire enough. The Tire Cleaner was sudsing white, and the brush was clean-looking and not black or brown. But I just looked at the first tire I did and the coating was already cracking and a little brown.
Back to square one. At least I don't have to take the wheel off again.
The sun is setting fast and I am not going to finish this project today. Uff. This better be worth it in the end!
What product are you using to clean the tires with before you applied the tire coating? Sound like you might potentially have an adhesion problem with the coating itself trying to set up.
I started with Megs APC and then followed up with Tuf Shine cleaner.
I will tend to take a clean white terry cloth towel after cleaning my tires to get a visual. Sometimes tire cleaning can be more time consuming then you would think. If the tires seem to be clean then the next step would be to decide on weather there was a mistake on the coating application. Maybe too much product was used. I just got done reading this thread and it seemed like mike had great success using a brush to level out out the coating. I hope this helps.
I used the brush method of application.
I suspect I should clean the tires and wait overnight to see if more old dressing etc. weeps out of the tires.
By Meghan in forum Off-Topic
Last Post: 11-26-2013, 01:37 PM
By a114m4 in forum Off-Topic
Last Post: 05-02-2013, 08:56 AM
By Meghan in forum 2013 DetailFest
Last Post: 03-25-2013, 04:39 PM
Last Post: 02-20-2012, 09:48 AM
By Donnym in forum Auto Detailing 101
Last Post: 08-24-2010, 06:52 PM
