Coatings on single stage paints
I was wondering what your experience has been using coatings on single stage paints? I know that single stages tend to oxidize and get that chalky look to them if they are not fed the oils that they need (ie Meguiars #7), and I was wondering if the coatings help stop this from happening.
Most coating appear to be made for a base coat/clear coat paint.
Thanks
Re: Coatings on single stage paints
I think that depends upon the age of the single stage paint.
An old single stage paint is going to need regular polishing using a product like the #7
A new single stage paint, especially a modern single stage paint which would be urethane instead of lacquer or enamel, will coat just fine in my experience.
So do I read this correctly in that modern ss paint is a urethane base and does not benefit like older ss paint from the #7? I have a 2006 Toyota that is ss, and have wondered if there would be any benefit to incorporating #7 into my next detail.
nice info here! I'm correcting a white ss 09 Camry today and was also wondering if it would benefit from the opti-coat
A few years ago I asked Dr. David Ghodoussi about using Opti Coat II on single stage paint and he told me he formulated it for clearcoats.
I used it on a new singles stage paint system that I polished to perfection and it seemed to apply and cure just fine.
If this is the product you want to use and the paint is perfected before hand I would say go for it.
December last year, I Opti Coated my 2011 Mitsubishi L200 with single stage Rosita Red paint. I went the Opti Coat route because I rather polish out a layer of Opti Coat than polish and remove the original single stage paint every time I get swirls or scratches.
The only regret that I have is that, I should have Opti Coated my car much sooner.
Originally Posted by Mike.Phillips@Autogeek;105565203.jpg[/IMG
Has the paint been neglected? Is it dried-out and oxidized?
Certainly not to the extent typically seen when people use these terms. It's a 2006 that I bought from the original owner in July 2012. I think he was pretty typical of many owners out there - very good about keeping up on maintenance items, but the paint probably never saw a polisher or a quality LSP until I purchased it. Washes were probably at the local swirl-o-matic.
There just seems to be something missing. I know white will never have the wow factor of other colors. I just have not been able to acheive the "richness" I've seen on other well polished white vehicles, and wondered if perhaps this modern ss paint might benefit from the #7.
Great information here. So the question remains, if the single stage is newer, say mid 2000's and up and has been neglected to the point of chalkiness and is polished out to a high gloss and prepped properly can Opti Coat be applied without incident?
PCB Reflections LLC
Specializing in Corrections and Protection
Servicing Greenville SC & Surrounding Areas
Originally Posted by eds72
I just have not been able to achieve the "richness" I've seen on other well polished white vehicles, and wondered if perhaps this modern ss paint might benefit from the #7.
What have you done to the paint so far as it relates to polishing it and restoring it since you bought it?
You can get a lot of gloss and shine out of white paint but it all starts with decontaminating and polishing.
By Fishincricket in forum Off-Topic
Last Post: 01-12-2013, 01:40 PM
By kmsdetailing in forum Ask your detailing questions!
Last Post: 09-26-2012, 05:58 PM
By Becciasm in forum Auto Detailing 101
Last Post: 07-03-2012, 06:44 AM
Last Post: 05-01-2012, 08:47 AM
By Mannyl312 in forum Auto Detailing 101
Last Post: 02-25-2007, 10:11 AM
