Page 12 of 22 FirstFirst ... 23456789101112131415161718192021 ... LastLast
Results 111 to 120 of 215
  1. #111
    Aug 2014
    Re: My technique concerning the 3401, Menzerna products, and Hybrid pads
    Quote Originally Posted by Mike@DedicatedPerfection View Post
    List looks good.
    After wipe off of WDGPS 3.0, wait 12 hours minimum before a coat of Fuzion.
    In those 12 hours cure time, wont the car get dirty? Do I have to wash it again or can I just straight up apply wax?
  2. #112
    Oct 2013
    386
    Quote Originally Posted by GoodToGo1 View Post
    My process is applying the wax or sealant at night then do a coat of wax again in the morning. Shouldn't get dirty sitting there usually. Especially in a garage.
  3. #113
    Feb 2011
    Minot, ND
    12,365
    Quote Originally Posted by arisking View Post
    /\ This.
  4. #114
    Mar 2014
    93
    I worked today with fg 400 on bmw 5 series 2001. It was my firs job with good compound and some wool pads and i found that the paint was very hard to correct.
    Unkonown rotary mashine don't know if this can be a big problem.
    Tried menzerna wool pad it dusted a lot I get nervous because i heard that menzerna doesnt dust.
    Could not work with menzerna hard pad it was really hard to work with that very hard pad.
    Finished the job with menzerna medium pad and got let say 70% correction on very swirled and scrached paint.
    When I finished the job tried one more time will wool and wanted 95% correction I got that 95% correction but again dusting.
    Someone used menzerna pads how they compare to others. I liked a lot the medium pad .
    Every section I did i checked the pain for heat, It was not very heat or just a litle heat can I go up a litle with the speed because the mashine is uqnknown I dont know how much speed I can use it's like 10, 13, 16, until 28. I work with 16 when I went to 19 it dusted a litle even with medium pad.
    I worked the polish enough but didn't notice that from milky to transparent finish. I stopped the polishing cycle sometimes when th polish was hazzed sometimes when I worked longer i got that finished polish on paint when i even didnt need a microfiber.
    Thanks a lot for reading and helping.
  5. #115
    Feb 2011
    Minot, ND
    12,365
    Quote Originally Posted by ViGi View Post
    What machine are you working with? Rotary?
    Could you list what machine, pads, and how you are working them?
    Either style machine equipped with a wool pad and FG400 will not have any problems cutting through hard paint provided my technique is followed.
    For the most part Menzerna will not dust or dusts in very small quantities. Usually the result of using a brand new never used pad or over saturating the pad with product. Once you get in the sweet spot so to speak, dusting should be non existent.
    If you are working the polish so long that there is nothing left to wipe off you have gone completely through the working cycle and possibly instilled holograms.
    Would it be possible to get some Hybrid pads?
    Also where are you located?
  6. #116
    Aug 2014
    Hi Mike, is there any technique video for the Flex 3401?
  7. #117
    Feb 2011
    Minot, ND
    12,365
    Not knowing the speed capabilities of the machine is a problem. FG400 absolutley does not like to be run above 1200 rpm. This is the source of your dusting.
    I have not used any Menzerna pads. Again, do not exceed 1200 rpm.
    I am here to help. Don't hesitate to ask further questions.
    Best Regards,
    Mike
  8. #118
    Feb 2011
    Minot, ND
    12,365
    I have not put together a video showing my technique. But I can if you would like.
    Regards,
    Mike
  9. #119
    Aug 2014
    Regards,
    Mike
    I would very much like that. When do you plan on putting it together?
    Is there any dvd from Mike@AG that explains this?
  10. #120
    Feb 2011
    Minot, ND
    12,365
    No problem. Hopefully I have the chance tomorrow.
    Not that I am aware of.
  1. Correct Technique for MEnzerna products
    By ThepanchMX in forum Auto Detailing 101
    Last Post: 06-02-2018, 02:41 AM
  2. Question about the Flex 3401 and Hybrid pads
    By FocusSTguy in forum Ask your detailing questions!
    Last Post: 01-12-2015, 08:06 AM
  3. Hybrid pads to use with Menzerna Products
    By silv3rbakk in forum Auto Detailing 101
    Last Post: 04-05-2014, 11:32 AM
  4. Anyone used the 5" LC Hybrid pads with the Flex 3401?
    Last Post: 04-15-2013, 05:51 PM
  5. New 5" Hybrid Pads on Flex 3401
    Last Post: 07-12-2012, 06:59 PM
