Am I using too much? I had to go over it w CG QD to get rid of the steaking....
Anyone else have this problem? On the bottle it says it easier when you use less, but I dont feel comfortable using less when theres dust all over the car.
Yah, you are using too much. I have a heavy hand. I have learned less is more with detailing products. I have had the same issue with some other products - now I use them without a problem. Try it again. Make sure the dust is super light -else just wash it. It is not worth the worry or the work if you do end up swirling it!
What MF did you use? I just went out and used a liberal amount of PB S&W on my car. I used a plush Cobra MF and I had no streaking problems. I had to wipe several times to buff off the product but it came off and dried clear.
