DP interior surface protectant
Not impressed at all. Leaves smears and look's oily on the surfaces; figured to try something different since my 1Z cockpit cleaner was running low, but I guess I'll stick with the 1Z
Re: DP interior surface protectant
I have been using it and don't seem to have the same issue. I actually thought how it's nice because it's not too shiny and how well it spreads in addition to how long it lasts.
Probably just different interiors, I'm sure.
Did you clean the surface first? Or did you just throw it on and hope for the best? Did you try to buff off the "oily" high spots? Did you allow any dry time, or just apply and reach this conclusion?
I've never seen anyone have this issue before, either its the dashboard material not playing well or maybe some user error in there...
Back to the full-time grind.
I really like the Ultima line.
Plus I got it on BOGO so I now have a lifetime supply (kidding)
However, this stuff works great
http://www.autogeek.net/ultima-interior-guard-12.html
DP ISP is the best i have used. Never had a issue with it. Could be residue from the 1Z left over on the plastics?
I use Sonax dash cleaner best I have used yet and 1z deep plastic cleaner for real bad interiors
McKee's 37 Product Support
I'm surprised to hear this!
Couple questions:
1. Did you clean the surface first?
2. Was the surface WARM or HOT to the touch when you applied the product?
3. Does the surface have a texture or is it smooth?
1Z CockPit Premium is a much thinner product, so you may simply not be used to DP Interior Surface Protectant, which is a much thicker, more substantial formula (it focuses more on the protection side rather than an "interior QD" like 1Z does).
Did you shake well before using? I know my bottle will "separate" after sitting a while.
I do clean my dash every once in a while and I did clean it before the first time I used it
I don't have any oily high spots. I wipe it on and that's it. Stays looking good for at least a couple of weeks.
I have been using this for about 6 months now and have probably used it 4-6 times.
By pilotpip in forum Product Reviews
Last Post: 05-23-2020, 11:44 PM
By Angus in forum Product Reviews
Last Post: 06-17-2014, 05:59 AM
By Dubbin1 in forum Product Reviews
Last Post: 10-27-2010, 07:30 PM
By Dubbin1 in forum Products Guides
Last Post: 07-08-2010, 08:07 PM
By Ap2 in forum Auto Detailing 101
Last Post: 04-23-2007, 04:31 PM
