Headliner Cleaning
What is the best way to clean a cars headliner?
I was just about to post this.. I need to get out water spots from a headliner
www.deep-gloss.com
Deep Gloss Auto Salon / Fine Automobile Detailing - Metro Detroit's Paint Correction Specialist
For Discriminating Automobile Enthusiasts Who Demand The Best
South East Michigan Automotive Detailing - Rochester Hills, Troy, Bloomfield Hills, Birmingham, Farmington Hills, South Lyon, West Bloomfield, Ann Arbor, Grand Rapids, Brighton, Grosse Point, Shelby Twp, Utica, Beverly Hills, Berkely, Walled Lake, Livonia, Novi, Wixom, Waterford, Clarkston
Here are a couple of threads dealing with that. Most common suggestion was water/Woolite mix. If I remember the ratio correctly, it was like 4:1 or 6:1.
Headliner Question
http://www.autogeekonline.net/forum/...headliner.html
Alban B-)
2008 Ford F250 XLT 6.4L PSD, 4X4, SC, SB, Bedrug bedliner, Torza Trifold Tonneau cover, SS step bars / Dark Shadow Gray Metallic
2006 Nissan Sentra 1.8S / Inferno
isnt there a good risk of damage to the foam backing
SELF BANNED
Headliners:
Require special care and attention, as cloth type headliners are assembled with foam backing and usually glued to a fibre roof panel. If the headliner becomes wet, it can cause the head liner to delaminate and fall down. An interior cleaner (303 TM Fabric & Vinyl Cleaner) should be used. Spray onto a terry towel and wipe very gently
Do not spray products directly onto head lining.Wipe lightly making sure not to leave headliner wet. Inspect and re-clean as necessary. It is better to clean twice, rather than to allow the head liner to get too wet. An alcohol based aerosol glass cleaner may also work for this operation because of its quick evaporation. Vinyl headliners should be cleaned the same way.
Methodology
· Lightly brush the headliner with a natural-latex sponge or a horsehair brush, they have very soft bristles that are gentle and is specially made for headliners or leather surfaces, this will loosen dust / dirt and make vacuuming easier (for very light dust or lint use a rolling lint brush)
· Do not use a stiff brush as you may snag or tear the headliner material
· Lightly vacuum the headliner to remove loose dust
· Spray 303 CM Cleaner & Spot Remover on to a 100% cotton terry towel
· Cleaning the headliner a quarter section at a time, use very light and even pressure on the towel to work the cleaner into the fabric. Do not saturate the material or use much pressure on the towel
· Use a fresh, clean damp, 100% cotton terry towel to remove the soil / dirt
· Frequently rinse the towel in clean warm water to ensure all dirt I soil is removed
· If the vehicle is fitted with a sunroof, open it a couple of inches, as dust build up at the front edge.
· Clean this area before closing the sunroof and proceeding to the rear of the sunroof.
Maintenance-use a Lint Roller to pick-up light dust and dirt
I used woolite upohlstry cleaner that comes in a spray with a terry towel and a bowl of water..
Before
After
Before
After
Before
After
www.deep-gloss.com
By Dusterbd13 in forum Auto Detailing 101
Last Post: 06-06-2020, 08:06 AM
By Calendyr in forum How to make money detailing cars
Last Post: 07-25-2017, 04:10 PM
By Cincy Colorado in forum Auto Detailing 101
Last Post: 08-03-2011, 02:30 PM
By 1flyfisher in forum Ask your detailing questions!
Last Post: 07-25-2011, 02:12 PM
By XLNTShine in forum Ask your detailing questions!
Last Post: 03-09-2011, 06:26 PM
