One of the best conditioners I've used is Howard's Leather Conditoners.
I love my RAV. Great car
Re: My new 13' Toyota Rav4 Ltd
Thanks HS… i'll look into the HLC's and see what they have available.
I have a '13 RAV4 in Spruce mica (dark green with gold metallic flake). I use a GG6 with Menzerna SF 4500 on a white 5.5" flat LC pad to remove light swirls from and give the paint that extra "pop" if or when needed. I use Menzerna Power Lock sealant and it really looks great. I am about to put on Collinite 845 this weekend but only to see how easy it is to apply and remove and see the finish.
Get a wheel spoke brush like this http://www.autogeek.net/spoke-wheel-brush.html. Also, get a long brush to clean the fender wells too since when they get dirty, it is really noticeable http://www.autogeek.net/mothers-fender-well-brush.html. I use 303 Aerospace Protectant on the inside and it lasts a long time http://www.autogeek.net/303aerprot.html.
Sent from my iPad using Tapatalk HD
Get a wheel spoke brush like this Spoke Wheel Brush, clean wheel brush, wheel cleaning brush, no scratch wheel brush. Also, get a long brush to clean the fender wells too since when they get dirty, it is really noticeable Mothers Fender Well Brush cleans wheel wells beneath the car's fenders. Fender Well Brush has a long handle to scrub behind wheels and tires.. I use 303 Aerospace Protectant on the inside and it lasts a long time 303 Aerospace Protectant, 303 aerospace, 303 protectant, aerospace protectant, 303 products, 303.
Hi Rick… so yea, I've got all those brushes you mentioned including a few others I couldn't pass up on. And I'll look further into the 303 as an interior cleaner.
Right now I'm just pretty much using Megs products for my interior which is doing a great job…and I'll continue to use them until I can find the "Perfect" products.
I still haven't decided on a polish or sealant yet.
The vehicle is only three months old and I've been washing it by hand since day 1.
I live out here in the AZ desert and would really just like to protect my car from the harsh climates.
Was looking into either WG's DGPS 3.0 or Megs Mirror Glaze 2.0 which is much cheaper as a sealant.
So how did you like the collinite#845?
Just finished with the 845. It is more work to take off by hand than Menzerna Power Lock (both applied by DA buffer). I'll have to see how it holds up. It does shine well, but so did Power Lock. At this point, I could live with just using PL.
303 Aerospace Protectant is not a cleaner, although they do make a 303 Cleaner. The Protectant really lasts quite a while compare to anything else I've used.
I've replaced all interior, licenses plate and reverse lights with LED bulbs. Also added a mirror with Homelink.
Here's a picture just after using Menzerna PL:
Softex is man made and not leather. Any product used to clean vinyl will do the job.
Rick....now in North Texas
Hey Rick, I too switched out all my interior bulbs for lead's… also swapped out my fogs for led's as well.
My lows are high beams were switched out too so everything matches.
I havent gotten around to the reverse and license plate bulbs yet.
If you don't mind me asking, what bulbs did you go with for those?
Do you have a link?
Hey there RTexasF…. good to see ya bro!
I had hazing on the hood from the Collinite 845 about three hours after I applied and wiped it off. I read about this and seems common. It's been 80 degrees all day and car is parked in the garage so I didn't think I would run into this problem. Used QD and wiped it down again and all is good again. This is the first time a wax has ever hazed up after wiping off all of the wax. Strange.
Last Post: 12-11-2020, 04:13 PM
By ScottH in forum Show N' Shine
Last Post: 11-21-2016, 07:45 PM
By ~TumbleWeed~ in forum Off-Topic
Last Post: 11-21-2014, 05:23 AM
By 281 in forum Show N' Shine
Last Post: 02-23-2014, 11:16 PM
By FFguy808 in forum Show N' Shine
Last Post: 05-27-2013, 03:20 PM
