When is it going to be our turn?!
It seems like just about every tool imaginable is now available in a cordless version. They've come a looooooong way in the past decade with regard to powering tools via battery - even the ones that you would never think they could: chain saw, radial arm saw, etc. Not only that, they're making them work for quite a while on a single charge,.
My question is when is the industry going to recognize the need - our need - for a cordless DA? Imagine the possibilities and the freedom... OMG the freedom!
Is anyone aware of anything currently even in R&D for a cordless DA? T'would be awesome! And sure, just like everything else that hits the market, the first version is going to be expensive but I'd guess within a year or so after the prototype drops, the prices would come down to the reality level.
Thoughts...?
Re: When is it going to be our turn?!
Man that would be the thing to have, cordless DA would love to have one...
I've thought about it as well. You would need a ton of battery packs. Most cordless tools lack balls.
It would be nice, but like any cordless tool, peak power will be right at the beginning.
I think an effective cordless da is still a decent time away. Battery powered tools have come a long way with lithium batteries, polymer lithium, lithium manganese. The problem is still weight vs run time with the batteries. For a battery to have enough capacity to power a 500w da for long enough to polish an entire car it would have to be heavy. A heavy battery would mean a very heavy da and cause some serious arm fatigue. an alternative would be a battery pack, but that means a power cord which is what you're trying to get away from.
Then there's the problem with voltage drop as the batteries drain. You set your speed to 5 to start a section pass and after a few sections speed 5 is the same as speed 3.
Last, who wants to deal with a battery dying in the middle of a section pass with something like m105 and have to deal with removing it?
Batteries have come a long way in powering tools, I just picked up a cordless 36v blower I use to blow dust and leaves off of my boat that I love. Maybe in a few more years there will be smaller higher capacity batteries that won;t have voltage drops.
I'd kill it quick unless someone was to come up with some special batteries and motor to at least do half of the car or had plenty of extra batteries.
I have no problem using a DA with a cord.
That would be really cool to see, but I can't see that happening anytime soon
Galatians 6:9And let us not grow weary of doing good, for in due season we will reap, if we do not give up.
I would rather deal with a cord then the added weight of a battery pack. One or two extra pounds really matters when you are using the tool all day.
You would lose the consistency .... as the battery was draining your speeds wouldnt be the same anymore so setting it to say 6 on your DA would end up changing once it started dying, which I can imagine would be pretty quickly doing correction work. However, if you had a cordless DA you used to apply wax now that could be useful!
2005 Jeep Grand Cherokee Limited
"Every expert was once a beginner"
Last Post: 08-15-2019, 08:13 PM
By johnZ71 in forum How to make money detailing cars
Last Post: 06-07-2014, 08:03 PM
By jamores23 in forum Show N' Shine
Last Post: 01-11-2012, 12:58 PM
By AjNavo61490 in forum Show N' Shine
Last Post: 06-06-2011, 01:44 PM
By Whitethunder46 in forum Off-Topic
Last Post: 03-06-2007, 11:14 PM
