Road film left after using ONR
After using ONR today I noticed that it didn't get all the road film off the vehicle. The dirt was gone, but the film remained. I found I either had to scrub it off or a spay of APC on the panel before cleaning. Has anyone else experienced this? I'm considering adding an ounce of OPC to the mix or to my ONR presoak to see if it cuts through it.
I believe the film must be a slightly oily road grime that ONR doesn't remove as well as a good 2BM wash.
Chris
Re: Road film left after using ONR
Optimum Opti Clean Concentrate, Opticlean cleaner protectant, Optimum all purpose cleaner protectant
Directions:
Dilute 1 part of Optimum Opti™Clean Concentrate with 3 parts water. Spray liberally on painted surfaces and wipe clean with a plush microfiber towel. Fold and use a new section of the towel as needed. For glass and interior surfaces, apply one or two sprays and wipe off with a clean, plush microfiber towel. For lower panels and wheels, spray liberally and let it soak for a few seconds and then wipe off.
VT
Originally Posted by glen e
to get rid of road film you either have to use a TFR ( Traffic Film Remover) or a cleaner or finishing polish. either way, you will have to renew the protection layer. no shampoo will get rid of it
I don't have any notable difficulty removing traffic films with a 2BM and wash mitt. No need for polish, no need for new LSP.
Thanks for the help guys. You pretty much confirmed what I was thinking. I'm still a little green at the onr washing and wanted to make sure I wasn't missing something.
Road Film can be an oily film "on" the paint that will wash off.
Over time, road film is more than just an oily film it's also oil mixed with all types of dirt and it impacts "onto" the paint and won't wash off.
I have two recent article on this with lots of pictures and the remedy besides washing.
Road Film - If you drive your car in the rain your car has road film
Driving in the rain - For most of us it's unavoidable
Road Film
Road film is the oily film splattered all over your car when you drive in the rain.
Where does Road Film come from?
Oils and other fluids that drip out of cars, truck and suvs accumulate on roads and highways over time.
When it rains, these accumulated oils and other fluids mix with the rain and are then splattered all over your car in effect staining you're entire car from top to bottom. The highest concentration of road film accumulates on your wheels, tires and lower body panels.
Just look in the parking space of any parking lot...
Motor Oil, Transmission Fluid, Gear Oil and other fluids
These outlined areas show where fluids have dripped off engines and transmission, even radiators and accumulated to the point that the pavement has been permanently stained.
It's also on roads and highways...
The oil stain line that runs down the middle of the road...
The dark line down the middle of the road
It's the darker, line down the middle of roads and freeways where most of the oily fluids accumulate as car, truck and suvs drive down the road.
Now that you've read this article and looked at the above pictures, you'll remember this every time you look down the road you're driving on.
Remember, oil and water don't mix
When it rains, the cars in front of you spray the rain water mixed in with these accumulated oils onto not only your car's paint but the wheels, tires, glass, plastic, cloth tops and vinyl tops.
If it's on the outside of the car then it's getting coated with oily road film.
Road Film builds up over time..
Oily road film builds up over time and because this film is oily or sticky it attracts dirt. This can be the dirt in the air or also in rain water that's splattered onto your car from the cars driving in front of you.
Can't always be seen...
Because the dirt staining effect caused by road film build up slowly over time it's not always easy to see, especially on black and dark colored cars, but don't be fooled, if you drive in the rain your car is getting coated in road film.
The solution to the problem?
Washing your car will remove any topical road film. The problem is the dirty, oil film will tend to migrate into any voids, pits, pores or interstices in your car's paint at least to the point that normal car washing won't remove it.
It's pretty easy to remove road film, all you have to do is periodically use one of the below approaches,
Use a quality cleaner/wax or AIO. The cleaning agents and/or abrasives in the cleaner/wax will remove any road film that washing could not remove.
Use a dedicated polish by hand or machine. Any high quality polish will effectively remove any built-up road film. Just be sure to apply a wax, sealant or coating afterwards to seal the paint.
Road Film... if you drive your car in the rain it's on your car...
__________________
Here's the other recent article, and remember... the realy cool hot rod in this picture is GARAGE KEPT
If the paint on a garage kept car gets dirty how much more so does the paint on a daily driver get dirty?
And if your car is NOT a light color, that is it's a dark color, then you're eyes cannot see the build-up of dirt or road film but it's there just the same... and to remove it you need to use,
- Paint Cleaner
- Pre-Wax Cleaner
- Compound or Polish
- Cleaner/Wax
Here you go...
Here's why you need to polish paint...
Video showing before and after
My buddy Mike owns this really cool 1932 Ford Phaeton with yellow paint that to the average person looks pretty good. But a little polishing using a tape-line shows why all of us need to periodically polish the paint on our cars, especially our daily drivers, and the reason for this is because the paint becomes stained with a film of dirt that clouds the true color of the paint.
Here's a section I've taped off on the cowel because me and one of our forum members already buffed out the hood when he stopped by to test out polishers.
On the left I've clayed the paint and then machine polished it twice and then applied a coat of wax. You can clearly see the left side is now a brighter color of yellow and the right hand side has what appears to be grayish film over the paint.
Here's the same picture above with graphics....
Of course I finished polishing the rest of the car to test out some new products...
Products worked well and now the dirt staining has been removed off the entire body and a coat of Max Wax has been applied.
The paint on your car gets dirty too...
The car in the pictures above is a garage-kept, sunny day only street rod, yet... the paint was still stained with dirt.
If the paint on a car that is always stored in a garage except for sunny days gets dirt stained paint, what do you think happens to cars that are daily drivers?
How about cars that are daily drivers but are never parked in the garage?
That's right... the paint gets a dirt film over it and for this reason in order to maintain the paint and see the true color you need to periodically deep clean the paint with some type of paint polishing process. Any of these approaches will remove the dirt staining over the paint,
- Using a one-step cleaner/wax
- Using a paint cleaner also called a pre-wax cleaner.
- Using a compound followed by a polish
- Using a medium, fine or ultra fine cut polish
If the owner of the above car had not used one of the above and instead used a finishing wax, or a finishing sealant, that is a product with no ability to clean the paint, what they would have done is simply "sealed the paint" and continued the staining problem.
Medium to dark colored cars
It's pretty easy to use a tape-line to reveal dirt staining on white and light colored cars but if you were to do this on a medium to dark colored cars, chances are good your eyes would not detect the change in color to the paint.
That doesn't mean the paint on dark colored cars isn't covered with a film of dirt, it just means you and I can't see it. It's there however, and it's important to periodically polish the paint to remove the built-up film of dirt and other contaminants.
Polishing the paint will restore clarity to a clear coat and it will restore the full richness of color to a single stage paint.
It will also prepare the paint for your choice of a wax or sealant.
If you choose to use a paint coating, you'll need to do an extra step to prepare the paint for the coating and it's always a good idea to follow the manufacturer's directions.
Now that you've read this article and looked at the pictures...
When is the last time you polished the paint on your daily driver?
It's probably polishing time...
Here's another article on this topic... any car that's a daily driver is going to need to have the paint cleaned once in a while...
Dirt in Paint or DIP - Stained Paint - Dirt Embedded Paint
Here's an example of what dirty paint looks like, note how where Marius has been machine polishing the green paint is now a lighter, brighter color of green while the un-touched paint has a darker, cloudier look to it.
Here's Marius showing Brandon how use the Porter Cable with Pinnacle Advanced Finishing Polish to "carefully" clean and polish the original paint after we first rubbed the paint down with #7
I used MS Paint to draw a line around the section to make it easy to see the before and after difference where Marius has buffed and where the original dirty paint remains. This is an example of DIP or Dirt in Paint also called,
- Dirt Staining
- Stained Paint
Here's the picture, not the difference in the color of green on either side of the black line...
Last Post: 07-08-2021, 09:47 AM
By TrustJesus in forum Auto Detailing 101
Last Post: 01-06-2021, 02:25 PM
By kenshotx in forum Auto Detailing 101
Last Post: 02-17-2020, 10:23 AM
By Booki in forum Auto Detailing 101
Last Post: 07-27-2017, 08:31 PM
By 87rx7chick in forum Tricks, Tips and Techniques
Last Post: 04-28-2010, 12:03 PM
26 | 27 | 28 | 29 | 30 | 31 |
