Souveran over Natty's Blue
Couldn't pass up the sale on Souveran, but have 2 coats of Natty's Blue on my car. Can I apply the Souveran over the Natty's?
Thanks!
I just did it today.
Looks amazing.
*Signature removed by admin.
Thanks!
Yep, this could only enhance what you have already achieved..
try spit shining it over top of natty's blue for the absolute best results.
NEOTHIN: Could you explain please that process??
spit shining 101-
1. have a layer of cured carnauba on the car (usually takes about 24 hours). When I say a carnauba has to cure, I'm talking about all the solvents that are in the wax have to evaporate leaving just the carnauba on the car.
2. take a spray bottle of pure water and put it into the freezer. Do not let it turn to ice. You want it to get as cold as possible without it turning into ice. When I spit shine, the top 1/2 inch or so of water in the bottle is ice.
3. now for the actual spit shining part. spray a small area of the paint with the cold water (somewhat generously). Then apply your carnauba over top of the cold water. make sure that the paint is cool to the touch before you start. apply until the droplets are gone. Let the nuba dry and then buff off with a MF.
Now for an explanation of what's actually happening here. If you have a layer of carnauba on the car, and then you apply another layer of carnauba on the car, the solvents in the second layer of carnauba will actually dissolve the first layer and the two layers will combine. The cold water spritz'd onto the surface keeps the first layer solid and doesn't let it dissolve. For example, collinite's 845 insulator wax is a good example. When the wax is warm, it's a thick liquid. When cool though, it becomes almost a paste because it hardens up. This is exaxtly what is happening on your paint. The cold water hardens up the first layer of wax to the point where the second layer's solvents cant dissolve it. Instead of having just one layer of wax on the car that is a combination of whatever you've applied, by spit shining the layers you apply, you have separate and defined layers of wax which helps the look overall (especially for showing the car off and you have 4, 5, 6, or more layers on the car).
VERY VERY INTERESTING
Thanks again.......i will try it.......
Only question that i have is when you apply the wax over the cold water, you say let the wax dry.......dry to a haze? or a little more than you did with the first un-watered wax application??
use the FOFO method. First On First Off. The first panel that you waxed is the first panel that you remove once the entire car has been waxed.
GREAT! Got it........ I Have a silver ride.........Souveran or Signature???
Thats a great technique, I can't wait to try it when my Souveran gets in
By ziggo99 in forum Product Reviews
Last Post: 07-22-2010, 07:23 PM
By Quick5Oh in forum Product Reviews
Last Post: 10-26-2009, 04:54 PM
By 4fit? in forum Auto Detailing 101
Last Post: 06-26-2008, 02:55 PM
By supercharged in forum Auto Detailing 101
Last Post: 07-28-2006, 06:31 PM
By Waxmax in forum Auto Detailing 101
Last Post: 06-07-2006, 07:17 PM
26 | 27 | 28 | 29 | 30 | 31 |
