Page 1 of 3 123 LastLast
Results 1 to 10 of 25
    Super Member BrianMcLeod's Avatar
    May 2013
    812
    Sanding headlights
    When sanding headlight with the PC to restore them what speed do y'all use on
    500 grit
    800 grit
    1200 - 1500 and final
    3000 grit
    Like my page on facebook ill like back - https://www.facebook.com/pages/Brian...668?fref=photo
    May 2012
    2,475
    500 grit is pretty aggressive. Most headlights won't need that. But for sanding you won't need a high speed. Maybe around 4 on the pc.
    Super Member hernandez.art13's Avatar
    Apr 2013
    6,958
    In this video (cheesy I know )
    I started with 1,000 and finished with 2500
    It was all done by hand though. I agree 500 is pretty aggressive, but at times it might be necessary.
    http://youtu.be/PgXCTMSUGU8
    Apr 2013
    6,958
    If doing that combo
    You can do
    500
    800
    1000
    1500
    3000
    Apr 2013
    6,958
    Still wondering if one can go from 800 to 1500
    And skip the 1000?
    Anybody know?
    Aug 2013
    81
    I've actually went from 800 to 3000 with great results. I've attached some photos
    Sent from my SAMSUNG-SGH-I317 using AG Online
    Attached Thumbnails Attached Thumbnails Sanding headlights-uploadfromtaptalk1383418089655-jpg   Sanding headlights-uploadfromtaptalk1383418112560-jpg
    Aug 2013
    Saint pete, FL
    59
    Re: Sanding headlights
    How do you know you've taken down of the oxidation when sanding? I tried wetsanding for the first time on some practice lights, I started out with 500 ended with 2000 then compounded and polished. After polishing it still wasn't clear so I went down to 360(lowest grit I had) and it came out better but looks like I will have to go down even lower.
    Did I do anything wrong or just didn't take out enough of the oxidation in the initial sanding? I used a rotary with 4" wool pad when compounding and polishing speed 3.
    Super Member Rsurfer's Avatar
    Jan 2007
    14,095
    Quote Originally Posted by Fury887 View Post
    800 should be enough to take out any scratches and oxidation. Do cross hatch sanding so you know if you removed the previous sanding marks. Use a bucket of soapy water and rinse often..work clean.
    Aug 2013
    81
    I just use the eye test, usually if by the time I'm finish with 800 and its not clear I know I need to sand a little more.
  10. #10
    Aug 2013
    Saint pete, FL
    59
    Sorry for the thread hijack. I tried the same process on these headlights today, you can see the left side was pretty bad. They made a big improvement but if you look closely the drivers side is much clearer(had less oxidation originally). I didn't even have to wet-sand it just compound and polish.
    Passenger side went down to 360 and in the sun you can still see a bit of yellowing and not clear like the drivers. What am I doing wrong? I'm going to go down to 220 and do cross-hatch unless im missing something.
  1. Sanding Headlights Help?
    Last Post: 11-30-2016, 01:05 PM
  2. Sanding for headlights
    By timsatx in forum Wet-Sanding, Cutting & Buffing
    Last Post: 02-09-2016, 08:16 AM
  3. Will sanding remove this from headlights?
    By rquino2000 in forum Auto Detailing 101
    Last Post: 11-19-2014, 11:01 AM
  4. What to use after wet sanding headlights?
    By Gsrjake in forum Auto Detailing 101
    Last Post: 09-30-2013, 10:13 AM
  5. Is sanding bad for headlights?
    By miniSguy in forum Auto Detailing 101
    Last Post: 09-19-2013, 10:16 AM
