Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Aug 2013
    Cleaning Rubber Door Seals?
    How does everyone clean rubber door seals? Whenever I go over them with a towel the towels just turn black.
    Aug 2012
    DC
    755
    All purpose cleaner, and a towel.
    Sent from my SAMSUNG-SGH-I777 using AG Online
    Super Member Audios S6's Avatar
    Oct 2011
    Shoreview, MN
    1,634
    Rubber can often take several application to fully clean.
    I'd start with an APC, might take a couple applications. If that didn't work, I'd ramp things up with degreaser, body prep solvent/IPA and lastly, trisodium phosphate if all else failed.
    None of these suggestions are exceptionally good for rubber when used frequently or left to dwell for long periods. Take care with any option and test in an inconspicuous location.
    A final option would be a pre-wax cleaner, which likely uses one of the aforementioned products. This can be much more tedious to apply, but result can be great.
    Static & Mobile detailing in Minneapolis & St. Paul. http://www.detailedcreationsmpls.com/
    Super Member swanicyouth's Avatar
    Mar 2011
    Limerick, PA
    9,388
    It's going to turn black if they have no coating on the seals. I use a rubber cleaner, like Griots.
    Super Member SYMAWD's Avatar
    Feb 2013
    1,667
    Re: Cleaning Rubber Door Seals?
    I use a towel and APC until no more black comes off, then I condition them.
    Super Member greatwhitenorth's Avatar
    Jun 2013
    B.C.
    356
    Quote Originally Posted by SYMAWD View Post
    +1 I condition with wurth rubber conditioner with the foam tip applicator thingy
    Super Member Rsurfer's Avatar
    Jan 2007
    14,112
    1Z Vinyl-Rubber cleans, conditions and protects. UV protectants.
    Aug 2013
    Thanks for the suggestions I was thing APC but wasn't 100% sure.
    Super Member oldmodman's Avatar
    Sep 2007
    2,563
    Then after the rubber is clean I go over them with Gummi Pflege.
    Einszett Rubber Care Stick Gummi Pflege, gummi pflege
  10. #10
    Super Member RedXray's Avatar
    Oct 2012
    The Detail Bay, USA
    850
    Just dirty I use PERL 3:1 on a soaked micro fiber corner, cleans and dresses. If there greasy APC then PERL.
    Second Best One Legged Detailer in The World... That top slot is unattainable
  1. Replies: 15
    Last Post: 09-28-2019, 12:47 PM
  2. apc safe for rubber seals and paint in door jams???
    By wantboost in forum Auto Detailing 101
    Last Post: 04-24-2017, 04:16 PM
  3. Do you 'detach' the door rubber seals to clean?
    By fellipe in forum Auto Detailing 101
    Last Post: 09-03-2014, 05:34 PM
  4. What do you recommend to put on rubber door and trunk seals?
    By gbrittenum in forum Auto Detailing 101
    Last Post: 07-11-2014, 09:37 PM
  5. cleaning under door seals?
    By embolism in forum Auto Detailing 101
    Last Post: 02-14-2011, 10:16 PM
