PH of car soaps on the market
I've been using CarPro Snowsoap, but I'm interested to know the PH level of the some of the other car soaps you all use out there. Did some research, couldn't seem to find any info here.
If there's a soap you use, and you happen to know the PH, please post here. I'm primarily looking for a soap that is strong, yet safe. Not worried about stripping off wax/sealants. Thanks to all who reply. -Ed
2013 Nissan Sentra SL (Arctic White)
2013 Nissan Altima S (Metallic Grey)
2012 Toyota Corolla S 5 speed (White)
Re: PH of car soaps on the market
Probably the way to go is to see if you can find the MSDS sheets for the various 'soaps' you're looking at.
Bill
Also, I think from a practical point of view, the pH level is only important after you dilute and mix it with water according to the manufacturer's directions, not testing it as it is in the bottle.
Just a guess...
Polished Bliss, (can I say that) lists the PH of the shampoos they sell in the specs section.
Interesting....
The pH will change from concentrated to diluted form, based on the pH of the water.
You'll want to take this into consideration when forming your opinion of products during testing.
FWIW PB lists a few outside the neutral majority.
On the acidic side:
Megs Ultimate Wash and Wax- 6
Two from Nanolex- 5
Two from Swisswax- 5
On the alkaline side:
Megs Shampoo Plus- 8
Auto Finesse Avalanche has a pH of 13 per the site mentioned earlier yet states it will not strip....who knows.
You can always use Litmus-paper to test the ph-values of car wash concentrates before and after dilution.
Comparing those results with the manufacturers' stated ph-values is an interesting exercise.
ph is just one factor that goes into formulating car wash shampoos.
There are blends of active ingredients, surfactants, conditioners, thickeners, etc...and as mentioned earlier:
The ph of the water (the universal solvent) used in the solution plays a role in overall car wash shampoo solution's ph-value.
Being ph balanced/neutral is just one way to look at acids and bases in a solution "cancelling each other out", so to say.
A "salt" is usually the end result.
Since much of the soilage collected upon a vehicle is acidic by nature:
Car wash shampoos that are slightly alkaline (7.1-8.5) would also be an excellent choice...IMO.
There are car wash shampoos that are acidic also.
I say:
'Save those for the engine bay;
and other such oils and greases,
that sometimes get in the way'.
NOTES:
1.) Car wash shampoos that are too ph-acidic/alkaline can wreck havoc on bare aluminum.
In no time flat!!
2.) AGO forum member PiPUK is a preeminent Chemist.
Perhaps he'll post some information regarding this ph subject matter.
By Thewashhouse in forum Auto Detailing 101
Last Post: 06-08-2018, 07:59 PM
Last Post: 04-17-2018, 01:22 AM
By BrianMcLeod in forum Tricks, Tips and Techniques
Last Post: 10-07-2013, 04:57 PM
By Charleston in forum Auto Detailing 101
Last Post: 11-21-2012, 01:40 PM
By Shane731 in forum Ask your detailing questions!
Last Post: 01-23-2010, 08:20 PM
