Page 1 of 2 12 LastLast
Results 1 to 10 of 18
    Super Member casvg5's Avatar
    Jun 2013
    323
    Microfiber polishing pads
    Ok, ive a wealth of knowledge and experience polishing with foam pads.
    Last night I tried to use some cutting and polishing pads. I could not get them to work right.
    Under any pressure the fibers just laid down and formed this big flat shiny matted down surface. Is that the surface youre supposed to polish with?? Im sure it shouldn't be like that. Im sure the fibers should remain fluffed and free and not matted down in one contimuous surface. Maybe Im wrong.
    I tried several times to fluff them with the pad cleaning brush, and even did a full clean with water and pad cleaner soap, and still, no luck.
    What am I doing wrong? I cannot seem to pull off a pad/polish/speed/pressure combo to get a flawless finish on this 35th anniversary Camaro I am working on. Ive blasted through all the swirls that were present, and now am just instilling small hairline scratches no matter how light or how slow I run my buffer.
    Sort of perplexed.
    Clarity Auto Detailing
    Houston, TX
    832.817.2606
    Super Member Evan.J's Avatar
    Sep 2012
    Pittsburgh, PA
    4,915
    Re: Microfiber polishing pads
    Ok well that will get matted down after one section pass but they are working.
    You need to be sure you are cleaning them after every section and not panel. They are best cleaned with compressed air over the conditioning brush.
    Working at a speed no more than 4 on any DA you will do a normal 6 section passes. Make sure then pad is rotating at all times. Once you do that section blow it out. When reapplying product less is more so very small 3-4 pea sized drops. Make sure you are changing you pads often as heat will kill them and cause them to fail.
    When your working with the cutting pad you will see a light haze and this is good. You will then need to remove the haze with a polish or the finishing pads and the finishing wax. I tend to go with a foam pad and polish though.
    Official Detailing Team Member of Air Force One
    Flex 3401 / Flex PE8 / Rupes 21 / G110v2 / GG6" / Rupes 75E / GG3"
    Click and Like my Facebook Page
    Jun 2013
    323
    Quote Originally Posted by Evan.J View Post
    So that big flat matted down mass that seems like it would mar the hell out of paint....is actually what youre looking for? That big shiny almost crusty surface of matted down fibers?? Really?
    Houston, TX
    832.817.2606
    Sep 2012
    Pittsburgh, PA
    4,915
    Quote Originally Posted by casvg5 View Post
    Yes thats how it should look after one section.
    Think about it how would those fibers stay fluffed up while polishing and applying downward pressure? They can't but just make sure you are cleaning the pads after every section.
    Sep 2012
    Pittsburgh, PA
    4,915
    here is the video
    [ame=http://www.youtube.com/watch?v=WhJYFLgIjhE]Meguiars Microfiber DA Correction System - YouTube[/video]
    May 2012
    96
    MF pads dont like any pressure and slower speed 4/3 finish better.
    Super Member Harry Da Hamster's Avatar
    May 2013
    863
    Which compound or polish were you using. Some people have reported that certain products don't work as well with MF pads.
    Jun 2013
    323
    Quote Originally Posted by anonymoususer View Post
    Chemical guys V36. Just turned into glue
    Houston, TX
    832.817.2606
    Super Member statusdetailing's Avatar
    May 2012
    Springfield, Mo
    1,325
    Used compressed air after each section. No exceptions. You need about 2-3 oscillations per second to get the best cut. Mark your bp if you haven't already. I get the best results around speed 4 on my griots. 5 if I'm edging and using pressure to remove a heavier defect. 2-3 med/heavy passes and 2-3 light quick passes. Prime the pad with 6-8 pea sized drops and then only 2-3 pea sized drops after that.
    Never use a wet pad. It will lose all effectiveness and also overheat and possibly delaminate. Keep them very dry.
    I spray them off with water and clean them with my extractor when I'm finished.
    Give these pads a chance. They are the future of detailing.
    Jeremy Wayne
  10. #10
    May 2012
    Springfield, Mo
    1,325
    I'd like to add that I hated these pads with a passion at first. I'm now getting unreal results in waaaaaaaaaay less time!
    Jeremy Wayne
  1. Microfiber Cutting pads VS polishing/finishing pads, any difference?
    By coupe07 in forum Wool & Foam Buffing Pads
    Last Post: 05-15-2015, 08:21 PM
  2. CG or Bns Microfiber cutting/polishing pads
    By parttimer in forum Auto Detailing Tools and Accessories
    Last Post: 10-29-2013, 08:56 AM
  3. Microfiber cutting and polishing pads
    By Znig22 in forum Wet-Sanding, Cutting & Buffing
    Last Post: 09-25-2013, 08:07 PM
  4. NEW Optimum Microfiber Polishing Pads - Used with DA Polishers
    Last Post: 10-17-2012, 10:42 AM
  5. Optimum Microfiber Polishing Pads?
    By MirandaAutoSpa in forum Auto Detailing 101
    Last Post: 10-27-2011, 11:18 AM
