Ipa wipe down with 70% isopropyl alcohol mixture question
What should the dilation be for an ipa wipe down using the 70% purchased at wal mart?
Re: Ipa wipe down with 70% isopropyl alcohol mixture question
Back to the full-time grind.
Here's a really great explanation of IPA wipedowns by Mike Phillips. Helped me understand dilutions and usage.
For a 12% IPA solution, 1:6 would be your dilution ratio.
The below is a "sticky" in the "Hot Topics" forum group because it tends to be a topic that comes up all the time.
How to Mix IPA for Inspecting Correction Results
Here's the answer....
70% IPA
To mix a 32 ounce Spray Bottle
8 ounces (or ˝ of a 16 ounce bottle) will make 32 ounce of 17.5% IPA to Water solution. Get a 32 ounce container, pour in 8 ounces, (or ˝ of a 16 ounce bottle) of the 70% IPA and then fill the rest of the container up with water and you get 32 ounces of 17.5% IPA to Water solution.
I use around 20%. First I dilute it as if the IPA was 100%. Then I figure the IPA is ABOUT 30% less than 100% (its 70%), so I add about 30% more IPA than the original amount of IPA I added. Easy to do in your head.
70% IPA
As always great info Mike.
2017 Shelby GT350, 2017 Dodge Charger Scat Pack, 2016 Focus RS.
Just be careful. A IPA wipe down can soften paint while wiping which will cause scratching/marring. It happens to my car every time I do a IPA wipe down. I switched to wurth clean solv prep instead.
I should point out that it is quite plausible that your damage is being caused by the lack of lubrication provided by IPA, a problem that will not exist with a panel wipe like you now use.
Does no one ever question why Eraser, a product with 30% IPA, does not damage paint at all when so many straight dilutions of IPA probably will?
By BobbyG in forum Auto Detailing 101
Last Post: 07-14-2011, 03:45 PM
By kimandbrad21 in forum Ask your detailing questions!
Last Post: 07-06-2010, 08:38 PM
By tWiStEd-tORqUe in forum Auto Detailing 101
Last Post: 08-08-2009, 08:59 AM
By Sonic Fury in forum Auto Detailing 101
Last Post: 10-31-2008, 07:51 PM
By texasdan in forum Auto Detailing 101
Last Post: 07-15-2006, 03:56 PM
