Re: How can I clean my lake country foam pads?
I use regular strength Simple Green but probably any decent APC will work - $10/gallon. I spray the pads well as soon as I pull them off and let them "soak" in a clean bucket until I'm done polishing. I do not fill a bucket with any solution as that promotes de-lamination. I use an old litter box but anything similar will suffice and place a grit guard inside. Re-attach the pad to my Flex and set the speed to #4. Only using the weight of the machine, turn the DA on for about one minute and guide it over the surface of the grit guard - do not bear down as you can damage the foam with to much pressure. Rinse with luke warm water and your done. The poor man's pad cleaner - works great and it's not messy believe it or not. I do wear nitrile gloves because I don't like handling the APC. Rinse the grit guard off and let the pads dry face down.
I actually have a 5 gallon bucket full of pads now. Warm water + Dawn or Snappy Pad Wash stuff if I have any. Let it sit overnight and then wash them out in the sink.
Hate it.
So I'm a little confused. Can I use Dawn soap or not? Also, does using vinegar help at all? If so, how can I implement the vinegar into it?
Originally Posted by AliMusa
So would simple green suffice?
Cut it 1:1 works great.
Just a suggestion...any pad you use for "synthetic wax," just clean as best you can and mark it for 'wax only' (or something like that). Reason I say this, synthetic products don't/won't be removed completely.
Of course, that is why we are going to 'sealers', longevity.
Bill
Simple green works great. I spray the pads and let them sit a few minutes and as I run them under water I add Dawn. If the pads aren't extremely saturated with polish jus use dawn.
I wick them in old towels and they can be used pretty much immediately.
That and Dawn or just Dawn.
Sorry but I'm terrible at understanding dilution ratios. How much of each would I need? Also, would I just put all three pads in at once in the same bucket?
Sent from my SCH-I535 using AG Online
What kind of dilution ratio with dawn soap?
I have used Dawn with success. My favorite is pad cleaner from XMT but, after a few squirts my finger slides off the pump part of the sprayer then I'm spraying my finger. (read whoever thought the type of prayer for the bottle is a knucklehead)
By VISITOR in forum Wool & Foam Buffing Pads
Last Post: 01-17-2018, 06:41 PM
By Equalizr in forum Auto Detailing 101
Last Post: 06-23-2013, 07:48 PM
By TS656577 in forum Auto Detailing 101
Last Post: 04-29-2011, 06:59 AM
Last Post: 01-08-2008, 08:03 AM
By supercharged in forum Auto Detailing 101
Last Post: 12-26-2006, 12:22 PM
