Page 1 of 2 12 LastLast
Results 1 to 10 of 14
    Aug 2013
    106
    How to best clean LC Hydrotech pads??
    I used some LC Hydrotech flat pads yesterday for the first time. I must say, these pads seem to perform EXTREMELY well! However, I am very new to detailing and machine polishing and have only used one other type of pad before - Hex-Logic foam purchased from Chemical Guys - so I really don't have much to compare them to.
    The one thing I did discover though is that they are WAY harder to clean than the hex-logic pads. I have a Grit Guard Pad Washer system, and even that didn't seem to get all the residue out of the Hydrotech pads. I realize that they are a different kind of foam composition than the hex-logic, but does anyone have any suggestions on how to efficiently clean Hydrotech pads both on-the-fly and after the job? (More so on-the-fly)
    I will probably buy more pads so I can have the option of switching to a fresh pad while working, but would still like to know how to better clean them.
    Thanks!
    Super Member The Pad Man's Avatar
    Mar 2006
    Wisconsin
    318
    Re: How to best clean LC Hydrotech pads??
    Fill a bucket with warm water and pad cleaning solution. Agitate by hand under water to circulate the cleaning solution through foam. Rinse with clean water, squeeze between a towel, let dry.
    Aug 2013
    106
    Thanks Pad Man. What about for on-the-fly cleaning?
    Apr 2013
    Las Vegas
    1,172
    Definitely don't use a brush, mine got destroyed by it after just a few seconds.
    Regular Member Eric M.'s Avatar
    Jun 2013
    Ontario, Canada
    141
    I spray mine with apc let them sit for a minute and then use a brush to work the surface and rinse. I find they clean easier then regular foam pads.
    Aug 2013
    106
    Eric, that certainly was not my experience with them. Once again, I've only had hex-logic pads and they came perfectly clean with the pad washer or even by hand after a few sprays of Chemical Guys Pad Cleaner (which I would spray on them undiluted) and rinsing with water. The Hydrotechs didn't respond well to either method.
    Jun 2013
    Ontario, Canada
    141
    What polish u using? I use menzerna and use those pads every week. Odd you're having such problems.
    SELF BANNED
    Mar 2013
    PA
    207
    pressure washer. 5-10 seconds perfectly clean
    Super Member ScottB's Avatar
    Mar 2006
    South Florida
    18,803
    DP Pad Rejuvinator .... just mix some up !
    Scott
  10. #10
    Super Member CEE DOG's Avatar
    Jul 2009
    Florida
    7,358
    carefully, lol
    :dancebanana:
    Sky's the Limit Car Care
  1. Polishes to use with HydroTech Pads
    By charlestek in forum Auto Detailing 101
    Last Post: 06-09-2019, 01:35 PM
  2. HD Speed and HydroTech Pads
    By Mike Honcho in forum Auto Detailing 101
    Last Post: 11-25-2015, 07:35 PM
  3. Hydrotech pads problems : Bad batch? Bad Pads?
    By R4IDER in forum Ask your detailing questions!
    Last Post: 10-10-2013, 07:26 AM
  4. Hydrotech pads
    By WRXINXS in forum Wool & Foam Buffing Pads
    Last Post: 04-19-2012, 06:23 PM
  5. New hydrotech pads dirty?
    By CEE DOG in forum Auto Detailing Tools and Accessories
    Last Post: 11-25-2009, 03:03 PM
