Re: Help With New Kit
Why not get a GG6 instead of the Meguires DA? More power (meguires is the weakest) and you get a lifetime warranty with a great company.
Also if it were me id get a least 4 cutting pads. They tend to gum up a lot faster than polishing pads, and you're going want at the very minimum 4 of them to do the whole car. You'll get better results with a cleaner pad.
If I go with the Wolfgang DGPS 2.0, Would it be best to use their swirl remover and glaze prior? Or could I use the Megs Ultimate line?
I heard the Meguiar's vibrates less then the GG6. Is this not true?
Will I be needing more power then the Megs?
You can still use the Megs Line
If I had to choose I would pick the GG6
All the answers are in red.
I have the G110v2 and its good but I would take the GG6.
ok, I will check them out a little more and may just go with the GG6.
Thank you guys!
